Wiring Diagrams Gil 33470?
9 replies to this topic
#1 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted January 25, 2013 - 08:54 PM
Hello,
Does anyone have a wiring diagram loose for a GIL33470A Montgomery Wards tractor?  Or can you point me to a manual that would have it? It has a 401707-0131-01 Briggs and Stratton.
I could probably figure it out, but someone else along the way did a beautiful rewiring job that cooked a few wires, blew a fuse, and knocked out the light switch.  I don't have anything worth copying. I would rather have a wiring diagram that would guarantee I do it right!
Thanks!
Ben Wagner
#2 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted January 26, 2013 - 09:38 AM
No help on the manual, but I noticed the #'s are different in the title. Need that fixed?
#3 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted January 26, 2013 - 09:02 PM
Yes sir, Kenny, you can correct the title if you would be so kind.  The proper numbers are a GIL 33470.  I could have sworn it was right when I posted it... but then again, yesterday was a long day.  I guess my fingers had a little too much free rein!
Thanks!
Ben Wagner
#4 KennyP OFFLINE
  • 38,478 Thanks
  • 45,969 posts
Posted January 27, 2013 - 05:43 AM
Gotcha covered. Guess this is a hard to find manual?
  • superaben said thank you
#5 drbish OFFLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted January 27, 2013 - 07:05 AM
Hopefully this will help
Attached File  wiring diagrams.PDF   528.43KB   192 downloads
  • KennyP and superaben have said thanks
#6 drbish OFFLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted January 27, 2013 - 11:23 AM
You might be able to get toro to send you the manuals.They will send them free of charge.Here is the link to ask for them
https://homeownersol...23&PageID=30025
see while searching the web that they have in the past
#7 drbish OFFLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted January 27, 2013 - 12:36 PM
Think i found one that will get you on the right path>It has a wiring diagram
Attached File  MW Owner's Guide GIL-33416A through GIL-33419A.pdf   638.61KB   148 downloads
#8 drbish OFFLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted February 02, 2013 - 01:46 PM
I sent an email to toro and got a response from them that they had to get a manual from a third party and i will receive it in 2 to 3 weeks.Do not have this tractor but will have a manual to put on the site
  • sacsr said thank you
#9 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted February 04, 2013 - 06:01 PM
new restorer, I believe you have solved the mystery for me.  I finally got the wiring wound up today.  Thanks for taking time to hunt those down!  Somebody had tried to wire in extra lights and ended up (somehow) connecting a hot lead to ground and shorting the light switch.  It burned the light switch and most of the wiring, as well as the makeshift amp gauge.  Furthermore, grounding the hot on the ignition switch cooked most of the insulation.  Pulling off the spade terminals pulled off the back of the switch.
I ended up redoing the whole thing and it works great now.  All is said and done, and contrary to my fears, the engine still gives a good charge.  That earned a sigh of relief, too.
Lesson for all similar future "previous owners": add ins are great, but don't help if you don't know how!
I appreciate your (and everyone in the past) help getting manuals for these machines.
Thank you!
Ben W.
  • drbish said thank you
#10 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted February 04, 2013 - 06:35 PM
For reference, I also found an official wiring diagram from the Gilson service world for the 33470.
I uploaded it to the files area: http://gardentractor...9-wire-diagram/
Ben W.
