#%$& Rattle
14 replies to this topic
#1 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,179 Thanks
  • 2,256 posts
Posted January 25, 2013 - 08:07 PM
I converted a charger 12 to electric. Now that it is QUIET running the loudest noise is an annoying rattle from the belt tension idler and linkages. I discovered the linkages are mounted on shafts that extend through the "tunnel" and are secured by clips on the other side. Using a shim on the clip side and some grease at the mating sufaces I  limited the side to side movement of the shafts. i also shimmed and greased where the linkages mated to each other.  Now the loudest noise is the hum of the electric motor and me smiling.
  • Gtractor, MH81, Texas Deere and Horse and 1 other said thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 25, 2013 - 08:33 PM
Nice conversion. I see you were able to fit it all in there with that big lump of a Kohler still in the frame. Can you give us any more details on the electric drivetrain you are using?
  • CRFarnsworth said thank you
#3 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted January 25, 2013 - 08:38 PM
Looks like he has the electric motor in between the pair of Kohler flywheel shrouds.  Nice work!
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 25, 2013 - 08:41 PM
Ahh! Very clever. It keeps a stock look!
#5 IamSherwood OFFLINE
  • 8,395 Thanks
Posted January 25, 2013 - 09:12 PM
Yes, that's a smart idea, and nicely done.  Just gotta maybe try to hide the batteries a bit more, and
you'd be filling up the waiting room at the local Audiologist. Maybe a red decal on the batteries.
Very cool project. :thumbs:
#6 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted January 25, 2013 - 09:47 PM
Yes very cool indeed, how long of run time are you getting with that setup?
#7 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,179 Thanks
  • 2,256 posts
Posted January 25, 2013 - 10:41 PM
DH1   I can get about 1 &1/2 hours total of "quality" run time.  That is just run around driving with just me. It works well in parades pulling a  scaled down hay rack with grandkids.  At a tractor show a gentleman stuck his finger down the "exhaust pipe " and said I had never run the engine. I eventually raised the hood and showed him why.
  • DH1, MH81, IamSherwood and 1 other said thanks
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted January 25, 2013 - 10:46 PM
That is just plain KOOL?
#9 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted January 26, 2013 - 01:13 AM
Very nice job and I like the way you shrouded the motor.
#10 MH81 OFFLINE
  • 29,979 Thanks
Posted January 26, 2013 - 07:44 AM
Bet it gets lots of look overs at the shows, nice conversion and a great conversation starter.
Congrats on losing the rattle.
#11 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted January 26, 2013 - 08:16 AM
One of the best conversions I've ever seen. At 65 with 40 years of lovin' my Horses, that is saying
something!
Great conversion!  :thumbs:
#12 DH1 ONLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted January 26, 2013 - 08:19 AM
So you made a QUIET sleeper.
What are you using for a motor and did you stretch the frame?
#13 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted January 26, 2013 - 10:23 AM
Very nice conversion.
I have the same "noise" you are speaking of on a GT-14. The tension pulley is actually hitting the fender as it rotates.
Sounds like a piece of steel on a grinding wheel.....Duh, it is a piece of steel grinding.
#14 Cvans ONLINE
  • 7,310 Thanks
  • 6,392 posts
Posted January 26, 2013 - 10:43 AM
That is a really nice conversion!!!  :thumbs: Your idea of mounting the motor between the shrouds was just what the project needed to give it a finished look.
#15 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,179 Thanks
  • 2,256 posts
Posted January 26, 2013 - 11:57 AM
It is a G.E. 24 volt from an electric lift truck.  The frame is stock.
I'll start a thread in electric tractors soon. Here's a teaser.
  • DH1 said thank you
