What Is The Correct Seat?
20 replies to this topic
#1 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted January 25, 2013 - 12:20 PM
I don't know if Y'all remember, but I have a Bolens built Montgomery/ Wards Squire. I am back on restoring it and I am trying to figure out which seat pan is correct. Here is a couple of photos I found on the net.
And this is what's on mine..
And I have this that I can use.
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3484 Thanks
  • 2816 posts
Posted January 25, 2013 - 12:38 PM
the seat you list as being on yours, i find on a lot of Sears older models. I dont have any bolens riding models to compare, but some of the ones i've seen in the past had a seat with an oval shaped, instead of a round holes.
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4979 Thanks
  • 4413 posts
Posted January 25, 2013 - 12:46 PM
Hi Brian, best will be to ask your podex, which is the right pan :bigrofl:
  • 15135 Thanks
  • 15577 posts
Posted January 25, 2013 - 01:07 PM
OK, I'll ask. What is a PODEX??
#5 backwoods OFFLINE
backwoods
  • 2699 Thanks
  • 2834 posts
Posted January 25, 2013 - 01:17 PM
the seat that you show on your's looks similar to the one i removed from my 600 bolens that i scraped. are there 2 post that hold the seat down?
#6 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted January 25, 2013 - 01:21 PM
The seat pan that is on it has only two holes to mount it. they are side by side.
  • backwoods said thank you
#7 backwoods OFFLINE
backwoods
  • 2699 Thanks
  • 2834 posts
Posted January 25, 2013 - 01:23 PM
could you take a pic of how the seat is mountedand what the mounting and how plate is mounted might help ill see if i can dig out the 600 seat i have and get a couple pics of it. and most sears that i have seen only had one bolt in the center of the seat to hold them down.
#8 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted January 25, 2013 - 01:32 PM
I'm thinking that it should like the one if the first pic.
That looks to be almost identical to the seat on my 800.
#9 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted January 25, 2013 - 01:34 PM
I just went back out to look at this seat and it's not the right one for this GT. It originally had a single hole to mount it, someone drilled it to be bolted with 2 bolts.
#10 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted January 25, 2013 - 01:36 PM
I will post another photo of how it's mounted, and would really like to seat your 600 seat pan. Thanks!!
#11 jd.rasentrac OFFLINE
jd.rasentrac
  • 4979 Thanks
  • 4413 posts
Posted January 25, 2013 - 01:38 PM
podex = bottom, a$$
#12 backwoods OFFLINE
backwoods
  • 2699 Thanks
  • 2834 posts
Posted January 25, 2013 - 01:51 PM
its identical to the seat on the 800 that OldBuzzard posted but ill can i can find it still and take a couple pics for ya
#13 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted January 25, 2013 - 01:53 PM
podex = bottom, a$$
:bigrofl: :bigrofl: :bigrofl: :bigrofl: :bigrofl: :bigrofl:
#14 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted January 25, 2013 - 01:54 PM
Are you going to use it if you can find it?
#15 Texas Deere and Horse OFFLINE
  • 15135 Thanks
  • 15577 posts
Posted January 25, 2013 - 02:01 PM
Here is the seat spring mounting bracket.
