1965 Chief Hd Rework
10 replies to this topic
#1 JägerStein OFFLINE
JägerStein
  • 7 Thanks
  • 8 posts
Posted January 24, 2013 - 09:11 PM
I have a 1965 Jacobsen Chief Heavy Duty that was my mothers, I plan to turn this tractor into a super plowing/pulling tractor. For the colors I am going with Case power red and IH white. The 7hp Kohler has been replaced with a 65hp turbo charged, Intercooled Runsun Diesel. I need to hunt up the belt gaurd, mule drive and deck. Tires are three rib Double Coin 400-4.80 8 6ply for the front and 6-12 Double Coin 12ply rice/cane lug for the rear. I found Jacobsen front wheel weights 50lbs each and the rear weights are from a Farmall Super M front end 100lbs each. plan on running 5 weights per side. Tell me what you think, I will start posting photo of the tractor soon.
#2 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted January 24, 2013 - 09:16 PM
I think I want to see pics of that beast asap!  But for pulling, I don't think rice tires would be what you want????   Seems like the lugs would just bend & fold instead of biting in.
#3 IamSherwood OFFLINE
  • 8,395 Thanks
Posted January 24, 2013 - 09:21 PM
That was my first thought, when I read 65hp.
Sounds like you won't even have to put a plow on, to
turn up the ground.
#4 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted January 25, 2013 - 01:02 AM
That sounds interesting. You must be doing some serious mods to the frame! and what are you using for a rear axle? I know it can't be the stock 3 speed. Can't wait to see pictures.
#5 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted January 25, 2013 - 02:01 AM
Going from 7 horse to 65 might just work. I need to see this monster GT!
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 25, 2013 - 05:11 AM
Same here. Your drivetrain will need a serious upgrade to cope with 65 HP.
#7 mjodrey OFFLINE
Posted January 25, 2013 - 05:53 AM
Wow,65hp ,that will be an interesting machine.
#8 KennyP OFFLINE
  • 40,192 Thanks
  • 46,794 posts
Posted January 25, 2013 - 06:35 AM
Won't have to worry about power, just breaking things! This should be fun!
#9 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted January 25, 2013 - 08:05 AM
:picsoritsnotyours:
#10 JägerStein OFFLINE
JägerStein
  • 7 Thanks
  • 8 posts
Posted April 17, 2013 - 05:50 AM
First off sorry for being MIA, I have been down sick. Now on to the beast. I got the engines to fit and the hood now clears the turbo, Beefed up the stock 3 speed rear end. Now I am working on changing from belt to HD roller chain and I have pics just need to scan and up load them.
#11 KennyP OFFLINE
  • 40,192 Thanks
  • 46,794 posts
Posted April 17, 2013 - 06:12 AM
Thanks! Glad you got over the punys! I'll hang around for the pics!
