Kohler Id
9 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 24, 2013 - 07:51 PM
Are there any numbers any where else on the K321 to ID the engine besides the unreadable tags on the blower housing ? K321 is the only thing that is readable and that almost isn;t .
larryd
  • 14,664 Thanks
  • 15,449 posts
Posted January 24, 2013 - 08:29 PM
Larry, That is the only way. All the 314-214's used the same engine code. I can look tomorrow and get you some numbers off one of mine if you want.
  • larryd said thank you
#3 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 24, 2013 - 11:36 PM
I would appreciate that.
larryd
  • 14,664 Thanks
  • 15,449 posts
Posted January 25, 2013 - 10:36 AM
Larry, here is a shot of my 214 engine.
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 25, 2013 - 12:30 PM
Thanks Brian. This morning I was kind of cleaning the blower housing and someone wrote these numbers inside with a magic marker .
K321AQS
60343
9822193
So I take it that these are the model , spec , and serial no's , respestively.
larryd
#6 Texas Deere and Horse OFFLINE
  • 14,664 Thanks
  • 15,449 posts
Posted January 25, 2013 - 12:47 PM
Larry, The only thing you have to find is the correct model- K321AQS. Everything  else should bolt right up. I don't think the SPEC# has anything to do with the PTO shaft O.D.
  • 14,664 Thanks
  • 15,449 posts
Posted January 25, 2013 - 12:49 PM
K321AQS
60343
9822193
larryd
That also makes me think that someone has already been at least that far into the engine.
#8 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 25, 2013 - 08:31 PM
Brian I've been wondering the samething..I do have a question  since I do have the engine out and the head off .
Since the cylinder is in as good shape as it is and no ridge at the top , would you go ahead and pull the piston out and check things ?
I still wonder about having the 3 loose bolts which one I initialy turned one with my fingers .As soon as I find a valve spring compressor I am going to check quides and seats.
larryd
Edited by larryd, January 25, 2013 - 08:33 PM.
#9 JDBrian OFFLINE
  • 9,599 Thanks
Posted January 25, 2013 - 08:39 PM
The spec number can be important for matching engines. There are not that many numbers that cross over to the 60343 in the 314. The crank is 1.181" I think which is 30mm. This seems like an odd size but is a standard bearing ID.
#10 Texas Deere and Horse OFFLINE
  • 14,664 Thanks
  • 15,449 posts
Posted January 25, 2013 - 10:05 PM
Larry, If it were me, I would pull the piston and check the rings. I might even hone the cylinder and stick new rings in it. I bet the oil is coming from the valve guides, a lot of times people don't worry about the guides for some reason.
