Seat Repair
24 replies to this topic
#1 HDWildBill OFFLINE
  • 8,978 Thanks
Posted January 24, 2013 - 06:06 PM
The Craftsman I'm currently working on had some really big rip's in the seat and of course the foam was exposed and it really looked bad. So yesterday I decided to experiment on repairing, because a new on is a bit more then I wanted to pay out. So I decided to use some foam, wire screen and my plastic welder and start patching.
Here is the results:
I'm going to try and use some fine sandpaper and smooth it out some.  I'm thinking maybe a heat gun may work better then iron I was using.
Has anyone else repaired a seat?  If so what did you use and how did you go about doing the repair?
  • Cvans and boyscout862 have said thanks
#2 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted January 24, 2013 - 06:18 PM
Bill that's much better than having the foam hanging out. It looks like battle scars.
  • HDWildBill said thank you
#3 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted January 24, 2013 - 06:33 PM
Looks good, but I'd be afraid of it cracking next to that. Unless you have some way to soften the plastic.
#4 Cvans ONLINE
  • 7,075 Thanks
  • 6,292 posts
Posted January 24, 2013 - 06:40 PM
Looks much better than most repairs that I've seen. Nice work.  :thumbs:
#5 HDWildBill OFFLINE
  • 8,978 Thanks
Posted January 24, 2013 - 07:08 PM
Actually the wife brought that up as well.  It's a good point and not I really don't have a way a this point.  I was thinking using a heat gum may work better to just soften the plastic lay into the contour of the seat and then seal the edge's.  I was hoping maybe others had experimented with some repairs and we could compare notes.
#6 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 24, 2013 - 07:20 PM
I did one in the past.  I bought foam and "fake leather" lol, and went to work.  Very time consuming and hard at times because I had no idea what I was doing but it turned out great and was very cheap to do.  Damn thing lasted forever and as far as I know the guy that owns the tractor now hasn't replaced/repaired it.  The foam and the "fake leather" can be bought at Joann fabrics or Michaels.  Best part is you can pick any color you want.  Just an option.
  • HDWildBill and boyscout862 have said thanks
#7 Arti ONLINE
Arti
  • 1,366 Thanks
  • 990 posts
Posted January 24, 2013 - 07:30 PM
Looks like a great idea.  It likely will last better than you think.
#8 boyscout862 ONLINE
  • 13,440 Thanks
  • 9,385 posts
Posted January 24, 2013 - 07:45 PM
Bill,  what does your plastic welder look like?  Rick
#9 IamSherwood OFFLINE
  • 8,395 Thanks
Posted January 24, 2013 - 08:29 PM
Most repairs I've seen, are done with duct tape. :(
Yours looks good and strong Bill. As said, try someting to soften the surronding
mat'l. Armorall, or?
#10 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted January 24, 2013 - 08:35 PM
Bill, looks good. A buddy of mine does vinyl repair for a living. He used some stuff that looks like that liquid electrical tape. You might to be able to buy those kits Hobby Lobby.
#11 HDWildBill OFFLINE
  • 8,978 Thanks
Posted January 24, 2013 - 08:37 PM
Rick, It looks like a soldiering iron with a triangle as the tip.
#12 HDWildBill OFFLINE
  • 8,978 Thanks
Posted January 24, 2013 - 08:42 PM
I'll have to check that out, what does he use to support underneath?  I found that foam tended to push the plastic up when it got heated, but if I used Screen over it, it did fairly well.  The bad thing about doing it the way I did is trying to get the seat plastic to blend in with replacement plastic.  Oh by the way I used a black oil bottle.
#13 HDWildBill OFFLINE
  • 8,978 Thanks
Posted January 24, 2013 - 08:43 PM
FL how did you get the fake leather to follow the contour of the seat?
#14 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 25, 2013 - 04:26 AM
I cut an oversized pattern of the seat.....way oversized.  As I was putting it on I had to constantly trim.  I started at the top of the seat and worked my way towards the bottom.  It's hard to explain. Wish I had a video of it for ya. Here's a video I found that kinda shows what I mean in the beginning of the video.
http://www.youtube.c...v=l7WhPQC1D2QFL
#15 mjodrey OFFLINE
Posted January 25, 2013 - 05:51 AM
That looks alright,hope it last for awhile.
