Wanted
K321
3 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 23, 2013 - 02:59 PM
I am possibly looking for a good used K321 or maybe a good short block . Might consider a replacement Briggs and Stratton that will work in a Jd314 .
  • 14,730 Thanks
  • 15,470 posts
Posted January 23, 2013 - 03:05 PM
Larry, I would stick with the Kohler. But you could go with a K-321 or K-341.
  • larryd said thank you
#3 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 23, 2013 - 03:19 PM
That is what I am really leaning toward. Just questioning the Briggs possibility.
#4 JDBrian OFFLINE
  • 9,601 Thanks
Posted January 23, 2013 - 06:05 PM
Briggs probably won't fit without a lot of grief. You need to drive the trans. off of the flywheel and the PTO off of the crankshaft so it's much more complicated than a belt drive machine. The crank is low in those Kohlers which means it's hard to find an engine that will line up to the drive shaft. The drive shaft does not have U joints so it's necessary for the crank to line up with the transmission input shaft.
