Kohler K321
18 replies to this topic
#16 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted July 01, 2013 - 10:33 PM
Been awhile since I have worked on this. I have decided to take it all apart and replace the cam, as I can't think of anything else that could be the problem.Will let you guys know how it works out.
#17 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted July 23, 2013 - 09:27 AM
Well, I took the whole engine apart; put a new cam in it and new rings. It runs and starts GREAT now. I guess something was wrong with the cam.
#18 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,971 Thanks
  • 9,615 posts
Posted July 23, 2013 - 10:30 AM
I will throw this in here, even though you found your problem. Somebody else might need it.
Sometimes setting your points with a feeler gauge isn't the best. If in doubt, using a continuity light and set it by the timing marks.
#19 101 senior OFFLINE
101 senior
  • 239 Thanks
  • 372 posts
Posted July 27, 2013 - 07:31 PM
In addition to the things ljsted, I have seen two more. A cracked flywheel at the shaft and a carb screw that was swollowed and interfered w/ the valves. Good lhck.
  • LilysDad said thank you
