1886 Question
11 replies to this topic
#1 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted January 22, 2013 - 07:58 PM
Does moving the transmission selector lever to NEUTRAL also lock the linkage from the foot pedal to the trans?
If it wasn't so danged cold out, I'd go check, but thought I'd ask here first.
#2 mark843 OFFLINE
mark843
  • 141 Thanks
  • 252 posts
Posted January 22, 2013 - 08:07 PM
Yes.
If you have the 1886 in drive and the foot pedal is in neutral, will the tractor roll down a hill? Also how stiff/loose should the movement of the pedal feel?
#3 8tyman8 OFFLINE
8tyman8
  • 466 Thanks
  • 757 posts
I don't believe so the only thing that i would think is a Brake interlock like on the tube-frames and yes it Very cold had to do work on a onan carb my fingers are Frozen !!!
Edited by 8tyman8, January 22, 2013 - 08:08 PM.
#4 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted January 22, 2013 - 08:15 PM
This Q is about the 1886 FL.  It's in NEUTRAL, and the foot pedal doesn't move except if just a wee bit, maybe an 1/8" and it stops.
 At first I thought it was disconnecter/bound up somehow, but once I got it home I could see that it's connected to the trans, so I'm hoping the it is indeed just locked by being in neutral.
It was on a tilt trailer and rolled off of it with no problem, but then again, the lever is in neutral, not drive or park.
#5 mark843 OFFLINE
mark843
  • 141 Thanks
  • 252 posts
Posted January 22, 2013 - 08:17 PM
I just checked and with the lever in neutral the foot pedal does not move.
  • OldBuzzard and 426tractorguy have said thanks
#6 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted January 22, 2013 - 08:21 PM
It's the drive/neutral/park lever that's in neutral.  The foot pedal is in the center position as well, but won;t move more than a 1/8" or so.  I can see that it is connected to the trans and that the linkage there also moves just that wee bit.
It was on a tilt trailer, and rolled off of it just fine with the above configuration.
I'm hoping that being in NEUTRAL does lock it, and that I don't have to pull the seat/fender pan to get it working properly.
#7 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted January 22, 2013 - 08:23 PM
Thanks...that means that it will have a good chance of moving under it's own power once I get the engine running :D :D :D
Edited by OldBuzzard, January 22, 2013 - 08:24 PM.
#8 MailmAn OFFLINE
MailmAn
  • 389 Thanks
  • 776 posts
Posted January 22, 2013 - 10:04 PM
Have you tried putting it in Drive and seeing if the pedal will move without the engine running?  I'm assuming that the engine doesn't have to be running for the hydro pedal to move?
#9 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted January 23, 2013 - 05:08 AM
Yes,mine locks the foot treadle .
#10 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted January 23, 2013 - 10:37 AM
Dave,same here,in nuetral pedal does move
#11 nyrobbie77 OFFLINE
nyrobbie77
  • 106 Thanks
  • 83 posts
Posted January 23, 2013 - 11:18 AM
same on my 1250.  in neutral pedal doesn't move
#12 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted January 23, 2013 - 11:28 AM
The way it works is
Lever in park locks the parking pawl into the gear in the rearend and nothing moves including the pedal
Lever in the neutral removes the parking pawl from the gear and allows freewheeling. Hydro pedal still will not move.
Lever in drive releases pump bypass valve and puts hydro pedal linkage in the slot so you can operate pedal for forward and reverse.
  • MailmAn said thank you
