Removing Paint From A Seat
14 replies to this topic
#1 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 22, 2013 - 12:28 PM
I bought a JD317 last summer and the seat was solid but full of grey overspray. Little dots of paint all over it. I'm not sure what this paint was, perhaps a primer, but it did not want to come off with a simple wash. This winter I have been going at the 317 restoration one piece at a time and decided to tackle the seat. I tried lots of mild cleaners but nothing seemed to even loosen it. I tried scraping each little dot off with a box cutter blade and that worked but was super slow and scratched the seat.
Heres some pics of what it looked like.
I didn't want to use anything like acetone as I knew that would melt the seat. I tried paint thinner and car upholstery cleaner but nothing really helped. I thought I'd try abrading it off with rubbing compound. That seemed to help but was very slow. OK, GoJo  hand cleaner. That seemed a bit faster so I got a random orbit sander, put a micro fibre cloth over the base and started "rubbing out" the seat using lots of hand cleaner. It worked and took about an hour or so to clean 99% of the paint off the seat. There are still a few specks here and there but overall this technique worked well. It dulled the surface a bit but I can probably polish it back to a better gloss if I want. It looks much better now and I am impressed at the quality of these seats. I'm not sure it is the original, but it's a JD seat and I really wanted to save it if I could.
Results
  • mjodrey, Texas Deere and Horse, tex tractor jack and 8 others have said thanks
#2 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 22, 2013 - 12:37 PM
You did an outstanding job on the seat, just some good ol time usually works as you well foud out. I was going to suggest  mineral spiriits, don't want to get it to shinny and smooth, remember you have to sit on that seat and if it was to slick you could slid right off the tractor.
Dick
#3 Newpaws493 OFFLINE
Newpaws493
  • 1,366 Thanks
  • 1,810 posts
Posted January 22, 2013 - 12:44 PM
Lookin good from here, would be a shame to make it worse with a harsh chemical. Keep up the good work! :thumbs:
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 22, 2013 - 12:45 PM
I tried paint thinner which is pretty much the same as mineral spirits. It really didn't help much.
#5 Texas Deere and Horse ONLINE
  • 14,793 Thanks
  • 15,495 posts
Posted January 22, 2013 - 12:48 PM
JD., That seat turned out great. Like said above, you will shine that cushion up real quick by using the 317.
#6 Texas Deere and Horse ONLINE
  • 14,793 Thanks
  • 15,495 posts
Posted January 22, 2013 - 12:50 PM
 I don't remember when the cushion change came, but I think all the 314-317's came with the older cushion like the 110-140 had on them. This is the correct replacement cushion for your 317 and it looks GREAT!! :thumbs:
Very Nice Job saving it. :worshippy1:
  • JDBrian said thank you
#7 mjodrey OFFLINE
Posted January 22, 2013 - 01:46 PM
Nice job,Brian.
#8 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 22, 2013 - 01:56 PM
Great job Brian! The only other thing I have used is Bonami and elbow grease.
#9 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 22, 2013 - 04:57 PM
Thanks for the info on the seats Brian. I'm not that familiar with how they would have looked originally. Most that you see up here have had new seats at some point. My 314 has one of those big generic yellow seats on it. The vinyl on this JD seat appears to be very thick and coloured all the way through.
Chris, that's pretty much what I did only I used the sander to cut down on the elbow grease component.
#10 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 22, 2013 - 05:05 PM
That was a great idea!  I had a Boss that always said " Work smarter not harder" 'cause I would lift heavy things instead of taking the time to get a Fork truck lol. I would counter with " Time is money" :D
#11 HDWildBill OFFLINE
  • 8,975 Thanks
Posted January 22, 2013 - 05:26 PM
Nice job Brian.  The seat looks great!
#12 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted January 22, 2013 - 05:50 PM
Well done Brian, seat looks as good as new. As for it being original to the tractor, I say it is. It is the same seat that came on the 200 series, and since the 317 was released after the 200 series, I'd say you re good to go for being original. The later 300 series had almost the same seat type, but the cushion areas were much deaper.
#13 olcowhand ONLINE
  • 41,046 Thanks
  • 31,390 posts
Posted January 22, 2013 - 07:13 PM
Carb cleaner spray would get it off.  I've never known it to harm vinyl, at least it never has for me, and I've used it on seats myself.  But you have that seat looking good!
#14 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 22, 2013 - 08:16 PM
Carb Cleaner. I never thought of using that. I didn't want to go too harsh and damage it. I'll keep that in mind. I have to get the paint off of the piping or whatever you call that piece that holds the seat cover to the base. The carb cleaner might be useful there.
#15 HANKG OFFLINE
HANKG
  • 6,297 Thanks
  • 3,417 posts
Posted March 31, 2013 - 06:57 PM
Thats a great brian tip brian thanks.
