Cam
8 replies to this topic
#1 wh71 OFFLINE
wh71
  • 6 Thanks
  • 32 posts
Posted January 21, 2013 - 07:02 PM
Will an aftermarket cam make a difference. I have a 14 hp kohler bored .030 over
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted January 21, 2013 - 07:43 PM
If you are talking about a performance cam then everything I have read says you have to make modifications to everything in order to see a major difference. Like boring the carb bore larger ( If it is a Carter carb), milling the head and porting the intake port. among other things.
#3 wh71 OFFLINE
wh71
  • 6 Thanks
  • 32 posts
Posted January 21, 2013 - 07:49 PM
I am getting then head milled, I got the carb bored out, and I'm going to port and polish it. Thanks
#4 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted January 21, 2013 - 08:02 PM
Sounds great! I am sure some of the pulling guys can offer even better advice. Good luck :thumbs:
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 21, 2013 - 08:48 PM
I read a series of articles on a Kohler upgrade called Killer Kohler and by doing mods like you are doing they got a 12hp K301 up to 16-17hp if memory serves.
#6 wh71 OFFLINE
wh71
  • 6 Thanks
  • 32 posts
Posted January 21, 2013 - 09:33 PM
Thanks and in looking at cams from vogel manufacturing and lakota racing if anyone has opinions I would appreciate them
#7 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted January 21, 2013 - 10:20 PM
Before you start getting crazy on the engine mods check with your local club rules to make sure your not gonna get kicked out for having a hot tractor in a stock class. If its a stock class you and you get cam work its going to be pretty noticable
#8 wh71 OFFLINE
wh71
  • 6 Thanks
  • 32 posts
Posted January 22, 2013 - 06:26 AM
Thanks but I have looked at the rules and I can do all this
#9 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 22, 2013 - 07:53 AM
If you bore the carb, and port and polish make sure you cut the valve seats correctly also! And ABSOLUTELY get a cam !! No need to do everything else with out it!! Its a waste .
Edited by skyrydr2, January 22, 2013 - 07:54 AM.
