Bolens G174
229 replies to this topic
#121 boyscout862 ONLINE
  • 14846 Thanks
  • 9897 posts
Posted June 14, 2013 - 09:20 AM
You have done very well. If that was my tractor, I'd be very tempted to disassemble everything since some cobbler seemed to get into everywhere. You really don't have that many componentents left to explore and fix. I hope that the tractor gives you many years of pleasure after all the TLC you have given it. Good Luck, Rick
  • SamMC said thank you
#122 mcorso22 OFFLINE
mcorso22
  • 34 Thanks
  • 56 posts
Posted June 16, 2013 - 08:24 AM
Man what a great thread! I read each post. You did a great job on that tractor.
I was airborne in my army days, ive jumped out of alot of perfectly good aircrafts. Tho i didnt jump from one the C5 is really something.
#123 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted June 16, 2013 - 10:26 PM
Here are a few pictures after I cleaned the differential housing and the axle bearings.
Also a few pictures of my train wreck of a garage and my home made A frame to hoist
the engine when I split the tractor.
Edited by fxrs55, June 16, 2013 - 10:27 PM.
  • HowardsMF155, boyscout862 and SamMC have said thanks
#124 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted June 17, 2013 - 07:50 AM
Ahh yes, the "Little Giant" ladders really are useful, are they not?
#125 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted June 26, 2013 - 06:05 PM
"Well . . . We're waiting . . ." <---- (Read with Ted Knight voice from Caddyshack)
#126 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted June 26, 2013 - 09:47 PM
heh heh,  Well I am waiting also. Working on getting Parts and gaskets.
Doggone thing is just sitting in the garage mocking me. Its going to take
3 weeks for all of the gaskets to get here.  I was hoping to use it to push
a large pile of brush and leaves to the back of my property and
also a large pile of limbs and brush  at the inlaws leftover from the storm Sandy.
I am going to use my craftsman GT6000 to do the jobs now. I
removed the snowblower attachment yesterday and today I started
sand blasting the dozer blade for the GT so I can paint it and install
it. Here is a picture from a few years ago.
  • boyscout862 and SamMC have said thanks
#127 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted June 27, 2013 - 12:27 AM
Want to use my Cat D9H?
  • fxrs55 said thank you
#128 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted June 27, 2013 - 04:45 AM
Darn right I do, and you're so close to me here in NJ
I'll be right over and I can just drive it home. No need to
load it on a trailer!   Ha Ha And heh heh !
While  I'm there can we go for a ride in a C130?
Edited by fxrs55, June 27, 2013 - 04:47 AM.
#129 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted July 09, 2013 - 10:12 PM
I did some assembly of transmission and adjustment of pressure plate fingers.
Edited by fxrs55, July 09, 2013 - 10:19 PM.
  • HowardsMF155 and SamMC have said thanks
#130 Cvans ONLINE
  • 9322 Thanks
  • 7205 posts
Posted July 09, 2013 - 10:58 PM
You ought to get some kind of award for your persistence on this project. When your done with this tractor it should be good for another 20 years.
#131 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted July 10, 2013 - 07:34 AM
I remain in awe of your mechanical skills.  There is something about looking over the shoulder of an experienced machinist who is concerned about doing the job correctly, not just rushing through for a paycheck, or to get another unit on the road.  Positively inspiring!
#132 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted July 15, 2013 - 10:32 PM
So the tractor is setting in the garage mocking me while I'm waiting
for gaskets. I talked to Leonard at Sheaffers Tractor parts and he
told me he is waiting for the axle housing gaskets to come in
and he would been mailing all of the gaskets and parts I've ordered.
I have been working on this thing since February. This thing
has had one problem after another. This has been the most
expensive free tractor I have ever been given. So while
I have been waiting for parts I decided to remove the radiator
and sand blast the radiator housing and shroud. I also
scraped the rust and loose paint off of the radiator brackets.
I painted the housing,shroud  and radiator. With the radiator
removed I was able to clean and prime the front part of the
tractor frame. I spent about 3 hours tonight scraping off the
old gaskets from the differential housing. Boy those old gaskets
on the housing are really bonded on there. It takes a lot of
time to scrape old gaskets off being careful not to
gouge the aluminum housing. here are a few pictures.
Edited by fxrs55, July 16, 2013 - 04:57 AM.
#133 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted July 16, 2013 - 11:29 AM
Looks beautiful to me!
#134 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted July 19, 2013 - 09:27 PM
 Here are a few more pictures. I have almost everything
cleaned and all of the old gaskets scraped off. I found some
old epoxy on the inside of the clutch housing and because
of its location I think someone tried to fix the broken
front transmission cover with the epoxy. That didn't work
so the cover was welded and re machined to fit back
on the transmission.
Edited by fxrs55, July 19, 2013 - 09:35 PM.
#135 Cvans ONLINE
  • 9322 Thanks
  • 7205 posts
Posted July 19, 2013 - 10:07 PM
I sure hope that you are about done finding things to fix.
