Bolens G174
229 replies to this topic
#91 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted April 27, 2013 - 07:44 AM
Here is a short video of tractors first drive before I removed
fenders and seat.
  • HowardsMF155, Newpaws493 and SamMC have said thanks
#92 Newpaws493 OFFLINE
Newpaws493
  • 1379 Thanks
  • 1813 posts
Posted April 27, 2013 - 04:39 PM
Am I hearing grinding when you shift?
#93 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted April 27, 2013 - 07:57 PM
Ahhh no I mean Yes you can hear grinding. This tractor has been sitting at least 10/12 years
under a tarp after the original died and then a few more years uncovered until
I got it home back in February and sitting that long the flywheel is covered
in rust and the clutch disk is dragging on the rust. That video is the first time
the tractor has run under its own power in all those years. As I was driving it
I would go up a few small hills and push the clutch pedal in and slip the
clutch and ware some of the rust off. By the time I was done riding around
slipping the clutch it was working much better.
Hey thanks for watching my video.
Edited by fxrs55, April 27, 2013 - 07:58 PM.
  • SamMC said thank you
#94 Newpaws493 OFFLINE
Newpaws493
  • 1379 Thanks
  • 1813 posts
Posted April 27, 2013 - 08:41 PM
Thanks for sharing all these details, Keep up the good work! :thumbs:
#95 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted April 27, 2013 - 09:08 PM
Thanks for posting it.  I'd imagine you're as happy as can be right now with all that work paying off.  It's been great to follow along "Over your shoulder" so to speak while you did this.
#96 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted April 28, 2013 - 10:23 PM
I had time on Saturday so I removed the fenders
and the wheels. I am going to take the fenders
to work so I can weld the cracks in both fenders.
The wheels I removed so I can paint the transmission
and differential sections of the tractor. I am also
going to repaint the wheels while I have them off.
I'm also going to change the transmission oil
at this time.
  • boyscout862, Newpaws493 and SamMC have said thanks
#97 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 07, 2013 - 08:57 PM
Here are a few pictures of the fenders. I welded the cracks in both fenders
and used some body filler to smooth them out. I put the blade back together
while I was waiting for the body filler to harden. I also finished painting the rear
  • boyscout862 and SamMC have said thanks
#98 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 07, 2013 - 08:58 PM
Here is a picture of the hydraulic hoses that are getting tired.
I will eventually have to replace them. I would like to
find more of the plugs / dust caps for the ends of the hoses.
#99 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted May 07, 2013 - 09:12 PM
Nice work on the fenders. My hydraulic hose outer coatings also bit the dust when I had mine torn apart. I plan to replace as funds allow.
Dust caps:
http://www.discounth...ct_p/ag-cap.htm
http://www.hydraulic...-dust-caps.aspx
http://www.ebay.com/...s-/220436153251
#100 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 14, 2013 - 09:34 PM
Started to work on the very rusty seat.
I removed the vinyl seat cover and found that the
foam padding under the cover was soaked with water.
I have kept the tractor covered with a large tarp
when I'm not working on it so that water has been
in the foam for years. I am sand blasting the pan
at work and after that I'm going to weld plates
on pan to cover the cracks and rust through. I need
to repair a tear in the vinyl also. Need to look
into that process. Here are a few pictures.
#101 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 29, 2013 - 04:44 AM
I finished the seat and put it on and I reinstalled the hydraulics for the front blade.
I really wanted to push a big pile of leaves into the back of my property so
I tried out the tractor with the blade. Well the turf tires lack much grip
so I put it 4 wheel drive. Bad news, the 4 wheel drive doesn't work.
I brought the tractor back up to the garage and used the blade to lift
the front off of the ground and spun the front wheels. The front diff
seems to be working as it should. Everything spins as it should clear
back to the transmission. There seems to be no engagement of the
front drive from the transmission. The lever for the 4 wheel shifts
but something is askew inside. Any thoughts ?
#102 Cvans ONLINE
  • 9322 Thanks
  • 7205 posts
Posted May 29, 2013 - 12:14 PM
That tractor has come a long ways and is looking nice. Thanks for all the photos.
#103 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 29, 2013 - 11:00 PM
I have had some thoughts about the clutch not completely disengaging. I found that
I could move the drive shaft from side to side about a 1/16"  and this had me
thinking that the pilot bearing in the end of the crank might be part of my
clutch problems. So with the 4 wheel drive not working along with the clutch
problem I decided to split the tractor. I found that there was no pilot
bearing in the crank but someone had stuffed a make shift sleeve in there.
This was causing a lot of drag on the drive shaft so clutch wasn't going to
disengage completely. Drive shaft now is beat on the clutch end that
would go into the pilot bearing. Clutch disk looks like new as does the pressure
plate. Next problem is the splines are about shot on the transmission input
shaft. Also found that the gear case cover for the 4 wheel drive gears
was broken and welded at one time.  And whenever they were fixing
the gear case they put the front drive engagement gear on the shaft backwards!
Four wheel drive hasn't engaged sense someone welded case.
Here are some pictures..   Whats scrap metal going for these days.
  • C130A Flight Engineer and SamMC have said thanks
#104 Newpaws493 OFFLINE
Newpaws493
  • 1379 Thanks
  • 1813 posts
Posted May 30, 2013 - 06:23 AM
:good_job:
#105 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted May 30, 2013 - 08:52 AM
I sat enthralled with this thread reading start to finish this morning.  An amazing job done so very well with such attention to detail.  I take it you are a machinest by trade?
The detailed information on the progress is well written and well thought out with accompanying photo's and video.  You set the standard my friend, and that bar is pretty high now!  Somehow you have lifted a little of my depression over turning 50!
I could use a good machinest, if you ever decide to move to the left coast, contact me!  My avitar is my other favorite piece of machinery.
  • boyscout862, Newpaws493, fxrs55 and 1 other said thanks
