Bolens G174
229 replies to this topic
#46 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted March 28, 2013 - 08:59 PM
That is very cool. If the emblem is too big for the grill, place it on the back of the seat. Are you reusing the rings. I've done it many times over the years where just running croacus cloth around the rings brings them back to work like new. I find that the cleaning of the groves solved most of the problems. Keep up the good work. Good Luck, Rick
I am reusing the rings and I am cleaning them with crocus cloth. The rings
look very good and I don't want to put to much money into tractor
until I get it running and also see if there are other problems.
Edited by fxrs55, March 28, 2013 - 09:01 PM.
  • boyscout862 and JRJ have said thanks
#47 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted March 28, 2013 - 09:09 PM
I cut the old fuel filter open and it was clogged with
rust and dirt. I do need to clean and flush out the fuel tank.
I found an oem filter on E-Bay but the guy wants $90.
Really? $90 for a fuel filter  ( HA HA HA!!! )
#48 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted March 28, 2013 - 09:20 PM
I checked the side gap clearance on the rings and
all four rings are within factory tolerances.
I also sprayed the red insulating varnish on the
alternator windings and it looks like it might work
out well.
#49 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted March 28, 2013 - 09:36 PM
NAPA Gold 3264 is a suitable replacement, but a tight fit. The NAPA filter is 2 1/4" long, and is very snug when tightened back up. But $12 sounds better than $90.
Looking at yours, your canister is different. Is it threaded? On mine, the lower portion is held to the upper with four small set screws.
Oops, never mind. I enlarged the pics, I see the set screw locations now.
#50 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted March 28, 2013 - 09:43 PM
This is the smaller size emblem I made it today.
#51 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted March 28, 2013 - 09:45 PM
I did spend over 8 hours machining a 2 inch thick aluminum plate into a new transom plate
for my friends boat. At $80 shop rate that works out to $640. I don't make that much per hour
but that would be our shop rate.
yea but you got a nice tractor out of it. they go for good money. if it had a loader and was painted with new decals its 4500.00 to 5k tractor. but like i said if you need any info on the tractor or parts i have a friend name jim hixon in north jersey an he has alot of stuff for them iseki tractors and large frames. where in jersey are you located? im 5 miles from the DE bridge.. 90 bucks for a fuel filter hes nuts i got a iseki H1502 and i get my filters from napa
Edited by 1967bolens collector, March 28, 2013 - 09:49 PM.
#52 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted March 28, 2013 - 10:20 PM
I do realize what your saying I'm just trying not to get excited
until I get it running. It does look way cool just sitting there.
I'm in Tabernacle.
  • JRJ said thank you
#53 boyscout862 OFFLINE
  • 14843 Thanks
  • 9893 posts
Posted March 28, 2013 - 10:43 PM
Was your hone a glaze breaker or a truing type? I stepped up to a Sunnen truing and I think that it gives a slightly better job. You are doing a great job and I hope that you have it running soon. Good Luck, Rick
#54 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted March 29, 2013 - 07:51 AM
I'm in Tabernacle.
ok i know where that is... your tearing everything down an looks like your doing iit right so as long as shes got compression, fuel and air it should run.. "remember a diesel engine CAN NOT have air in the fuel system you have to bleed the injectors and theres most likely another bleeder screw some where before the injectors" i dont know if you ever worked on diesels before so i just thought i would throw that out there..
#55 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted March 29, 2013 - 08:32 AM
Looking good if you need the fuel filter I have the OEM ones here a lot cheaper the the ebay one.
Edited by bhts, March 29, 2013 - 08:33 AM.
#56 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted March 30, 2013 - 11:04 PM
I picked up a gallon of Rotella oil and I started to flush the oil passages.
I removed pipe plugs the check valve from oil pump and
the oil pressure sending unit. I then using a squeeze pump
pumped oil into the oil passages until it started to flow
out at the various bearings and lube points I also had
oil flow through the crankshaft. I also ran an M14 tap
into the head bolt holes to clean out the gunk and
some rust. I want the threads clean so I get the right
torque reading. Dirty threads will give a false reading
and the bolts most of the time will not be tight enough.
Edited by fxrs55, March 31, 2013 - 03:18 PM.
  • HowardsMF155, Newpaws493, JRJ and 1 other said thanks
#57 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted March 31, 2013 - 08:58 PM
Saturday I was able to do some more work to the tractor. I started by
putting rubber fuel line over rod bolts so they didn't damage the
crankshaft when I put pistons back in engine. I put my ring compressor
on the piston and pushed it into the cylinder. I did put assembly lube
on the rod bearings and installed rods onto the crankshaft. I finally
cleaned up the oil pan. It was full of black sludge but that sludge
probably kept the oil pan from rusting on the inside since
it had about a pint of water in it when I drained it. After I cleaned
the inside I sanded the outside which was rusty and blah.
After wiping it down with lacquer thinner and gave it several
coats of semi gloss black paint. After pan dried I installed it and
installed a new oil filter and filled the crankcase with fresh oil.
One of my big concerns was if the oil pump was going to work.
I pumped all of the oil passages with oil and put plugs back in and
installed the battery. I put motor oil in the cylinders and Cranked the engine
over with the starter. While I was cranking I keep spraying oil into the
cylinders and after about a minute or so I got oil pressure and oil came
out the oil line to the head and the rocker arms. I am so excited. next
up is I need to press two new valve guides into the head and assemble
the valves back into the head and install head onto the engine.
Edited by fxrs55, March 31, 2013 - 09:16 PM.
  • Cvans, boyscout862, JRJ and 1 other said thanks
#58 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted March 31, 2013 - 09:09 PM
Hard to not be an optimist at this point. It sounds like everything is going back together well. I'm hoping this goes good for you the rest of the way.
With mine operational, my original plan was to re-sell it for a profit. But after using the snowblower on mine, which I did a lot of work to, I have decided to keep my G152 and sell my other snowblowing tractor. Even though I'm going from a hydro back to a gear drive with the Bolens, I just love how little fuel these units burn. Liquid cooled engine that I could tap for a heater in a future cab had no bearing on the decision whatsoever.
I just wish I had your mechanical abilities and knowledge. Thanks for guiding us through this, I'm learning quite a bit.
#59 Cvans OFFLINE
  • 9315 Thanks
  • 7201 posts
Posted March 31, 2013 - 09:52 PM
I've enjoyed your project so far and your photos have been very good. Can't wait for the smell of burnt diesel.  :thumbs:
  • SamMC said thank you
#60 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted April 02, 2013 - 09:40 PM
Thanks.  I am working on this after I get home from work. We work 10 hour days
but I have been going in to work by 5 AM so I can sand blast
and paint parts for the Bolens.  I received some new parts in the mail the other day
so now I can start to reassemble. Monday I took the head to work to replace a valve guide.
I had to machine a tool to press out the old guide and press in the new one.
I bought two new valve guides but after checking all of the bores of the valve guides only one was worn out.  When I got home last night I was able to lap the valve with the new valve
guide so now all valves are ready for valve seals and then springs . I did install
the new valve seals tonight and then the new valve springs.
The head is now ready to go back on tractor.
Edited by fxrs55, April 02, 2013 - 09:40 PM.
  • boyscout862, Newpaws493, JRJ and 1 other said thanks
