Bolens G174
229 replies to this topic
#211 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted March 30, 2014 - 09:00 PM
Well it rained all day so I worked on the scoop in the garage
and here are a few pictures. I took it apart to scrape off
some of the rust and fix the latch and some loose bolts.
  • boyscout862 and Newpaws493 have said thanks
#212 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted March 30, 2014 - 09:50 PM
Worksaver is still in business: http://www.worksaver.com/
#213 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted April 06, 2014 - 07:01 PM
I sanded the heck out of the frame and outside of the scoop to remove
the rust. I looked at different types of rust sealer / paint and I
just did not want to spend as much money for paint and sealer as I did
for the scoop. So I sprayed everything with rusty metal primer I
already had and then I bought a gallon of rustoleum high performance
oil base enamel paint for $25 at Walmart. I bought the light grey.
Here are a few pictures. This week I am going to replace the water pump
and the head gasket. I hope that's it for the rest of the summer.
#214 Walkinman1 OFFLINE
Walkinman1
  • 773 Thanks
  • 599 posts
Posted April 06, 2014 - 07:49 PM
Can I request a video of that thing in action? :D Nice job on the refurb by the way...
#215 Cvans OFFLINE
  • 9315 Thanks
  • 7201 posts
Posted April 06, 2014 - 10:52 PM
You did a nice job on the scoop.  :D
#216 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted April 07, 2014 - 10:13 PM
I was using the tractor a good bit on Sunday and the water pump
is starting to leak more and it also now has a rumble sound.
Time to replace the pump and to replace the head gasket.
Here are a few pictures of the tear down.
  • Cvans, boyscout862 and Newpaws493 have said thanks
#217 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted April 22, 2014 - 10:25 PM
I finished replacing the head gasket and water pump last week and so far so good. My laptop
is down and all of my pictures are on it. I need to replace the power jack on the mother board.
I have ordered a new jack and hopefully it will be here soon so I can get to my pictures.
I used the tractor with the dirt scoop today for about 3 hours and yesterday I used
for about 3 hours and does do a good job. Plus it is fun as heck to drive around and
having a two cylinder diesel is actually cool as well.
  • HowardsMF155 and boyscout862 have said thanks
#218 boyscout862 OFFLINE
  • 14843 Thanks
  • 9893 posts
Posted April 23, 2014 - 05:03 AM
I'm glad that you are getting to enjoy the tractor. You have certainly earned it. Good Luck, Rick
  • fxrs55 said thank you
#219 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 12, 2014 - 09:56 AM
I have been using the tractor with the dirt scoop and I think
I need to replace the O-rings on the 3 point lift piston.
I have to give it a good bit of throttle to lift scoop with
dirt or stone in it. Also here is a video of the disassembly
of the engine to replace the head gasket and water pump.
  • HowardsMF155, Cat385B, boyscout862 and 1 other said thanks
#220 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 28, 2014 - 09:59 PM
I finally have a little time to address the weak 3 point hydraulics
when lifting stuff with my dirt scoop. Upon disassembly I found
the o-rings are shot and the piston has galling as does the
cylinder bore. I honed the cylinder and I'm going to take
the piston to work polish it in the lathe. I already
bought all the o-rings I need for this project.
  • Cvans, Cat385B, boyscout862 and 1 other said thanks
#221 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 31, 2014 - 03:58 AM
I finished rebuilding the hydraulic cylinder and reassembled
everything back onto the tractor. After bleeding the air
out of the cylinder I could not believe how much
better the 3 point lifts the dirt scoop with a load
in it. I'm glad I finally fixed it and it was such an
easy job I should have done it sooner.
  • HowardsMF155, Cat385B and boyscout862 have said thanks
#222 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 31, 2014 - 11:17 AM
Wow, those pictures stink. I'll repost them tonight after work.
  • Cvans and boyscout862 have said thanks
#223 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted May 31, 2014 - 08:42 PM
here's those pictures again. Nothing exciting. Whenever I have to
take something apart for repair I always chip my paint job.
Oh well it is what it is.
#224 Cat385B OFFLINE
    Tractorfanatics.com
  • 14747 Thanks
  • 10288 posts
Posted May 31, 2014 - 10:46 PM
I have the same issue, both my fenders have a ding or two. At least the weld and repair is holding where the fender attaches to the foot rest, where it was torn. Was yours like that also?
#225 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted June 24, 2014 - 05:54 PM
Here is another video of the head gasket replacement. This one is of the water pump.
