Bolens G174
229 replies to this topic
#136 boyscout862 OFFLINE
  • 14846 Thanks
  • 9897 posts
Posted July 21, 2013 - 10:49 AM
You are doing a great job. I look forward to it being finished too. Then you can post pictures of the FEL that you are going to build for it, right? I hope your parts come soon. Good Luck, Rick
#137 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted July 21, 2013 - 02:42 PM
Hey whoa, whoa . . . WHOA! :say_what:   Who said anything about an FEL? :hitting_self_roller:   now that I REALLY WANT TO SEE!!!  Go get 'em Rick! :wewantpics:  :smiley-flag003:
#138 boyscout862 OFFLINE
  • 14846 Thanks
  • 9897 posts
Posted July 21, 2013 - 04:33 PM
I just assumed that when the tractor was done that the FEL was the logical next step. Good Luck, Rick
BTW what is with the Swedish flag? My mothers parents came from Sweden in the 20s and my FIL was born in Sweden.
Edited by boyscout862, July 21, 2013 - 04:36 PM.
#139 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted July 21, 2013 - 09:07 PM
Heh Heh  I do get your message.  Subliminal suggestion to see if I'll take the bait.
As if you think I like a challenge. Not that I've checked but hydraulic cylinders
aren't in my budget this year. Don't care anyway so bite me.  ( <--joke )
Edited by fxrs55, July 21, 2013 - 09:08 PM.
  • boyscout862 and SamMC have said thanks
#140 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted July 21, 2013 - 10:16 PM
:tapping_fingers: LOL!
#141 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted July 21, 2013 - 10:17 PM
Jag ar Svensk :smiley-flag003:  . . . and some Kraut too. :beer:
#142 boyscout862 OFFLINE
  • 14846 Thanks
  • 9897 posts
Posted July 22, 2013 - 04:44 AM
My fathers grandparents came from Germany. My grandmother was living in NYC and was supposed to go on the ill fated ferry trip in 1905. She had to work instead, which saved her life. Funny how little things can make such big differences. Good Luck, Rick
#143 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted August 05, 2013 - 09:55 PM
Ok, I have been waiting for the axle housing gaskets and
I found out 12 days ago that they are no longer available!
I found a different supplier for the axle housing gaskets
and they came today. I can now get started on the
reassembly. Here are a few pictures of the new
gaskets.  Oh by the way the new gaskets
came hidden in a large sheet of compressed
gasket material.  This sheet is a direct replacement
for the old gasket material without the asbestos.
  • boyscout862, Newpaws493 and SamMC have said thanks
#144 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted August 06, 2013 - 07:26 AM
OO RA!  :smiley-flag003:
#145 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted August 11, 2013 - 07:18 AM
Started to do some assembly. I now have all of the gaskets.
Edited by fxrs55, August 11, 2013 - 07:31 AM.
#146 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted August 11, 2013 - 06:30 PM
Making some progress
#147 Cvans ONLINE
  • 9322 Thanks
  • 7205 posts
Posted August 11, 2013 - 09:56 PM
That sure looks nice. Do you remember where all the parts go? I have to put everything in labeled baggies or I'm lost.
#148 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted August 12, 2013 - 04:55 AM
The longer I'm away from a project the more I forget were things go. If you look at some of
the earlier pictures you will see that anywhere I could put a nut or bolt
back were it came from after disassembly I did put it back. I also take
pictures and in some cases I bag things also.
#149 C130A Flight Engineer OFFLINE
  • 184 Thanks
  • 154 posts
Posted August 12, 2013 - 08:13 AM
Rick, you have proven yourself yet again.  I have been working on aircraft and building T56 engines for over 30 years.  I still put the hardware back where it came from wherever possible, not just to assist my memory (I have a good memory, it's just real short).  When encountering long breaks in a project things get moved and/or scattered and invariably lost.  Keeping all the pieces together reduces the possibility of loss and a great deal of future frustration.
It also helps to identify incorrect hardware.  If you are working on a project someone else has been into before, many times it was reassembled with incorrect or inferior hardware that causes either future or immediate problems that can effect safety.  Even though these antique garden tractors are a hobby, they are still "Outdoor POWER Equipment".  If they are improperly maintained or operated they can bite you.  I have found that if something isn't looking right, it probably isn't. Many pieces of hardware look alike, but are not.  Engineers look at the application of hardware and determine if the attaching hardware is in tension, shear, torsion or a combination of stresses.  Bolts are of different grades to deal with those types of loads and installation of the correct hardware is critical.  Connecting rod bolts are a good example.
Consulting the parts book or others who have tackled similar projects as seen in this and other forums always makes the job easier and more satisfying when you know it is done and done right to high quality and exacting standards.  That's not to say occasionally shortcuts don't work, for example I am hard pressed to think of a time I got it wrong setting ignition points with a matchbook cover. :D
All who have watched this thread develop I am sure have learned many valuable lessons and gained outstanding insight on how a "professional" can approach his "hobby".  Well done!  Looking forward to seeing the finished product!  :dancingbanana:
#150 fxrs55 OFFLINE
fxrs55
  • 342 Thanks
  • 246 posts
Posted August 12, 2013 - 11:12 AM
Setting what with a what?  ( Ha Ha !!!)
I miss ignition points mmmm a little.
Also my name is Don, so who is Rick?
