Mf1650 Axles...tapered Or Straight?
9 replies to this topic
#1 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 17, 2013 - 05:00 PM
Anyone here know if the MF1650 axles at the hub are straight keyed, or tapered with key?  I know the MF14 is straight, but never had the need to pull one off a 1650 to know.  The only manuals I have is for a Snapper 1655/1855, and the snapper 1650 & those manuals all show straight keyed, when I know the MF1655/1855 are tapered.   I have some projects going requiring swapping some wheels/tires to get the offset I need, but if the MF1650 axles are straight, then I have no 6 lug straight keyed hubs to fit.
  • 15111 Thanks
  • 15570 posts
Posted January 17, 2013 - 05:58 PM
Daniel, I have a set of WH D200 axles with 6 bolt hubs. I don't know if they are tapered or straight. You can have them if they are right. Let me see if I can find out about them.
  • olcowhand said thank you
  • 15111 Thanks
  • 15570 posts
Posted January 17, 2013 - 06:32 PM
The WH hubs are straight bored and keyed. Now if they are the right DIA.?
#4 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 17, 2013 - 06:37 PM
The MF14 axles I believe are 1 1/8", but I'll have to check to be sure on this 1650.  It will be a while before getting to this point, so there's no rush.  I can compare part #'s between the 14 & 1650 hubs to tell the tale.
#5 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 17, 2013 - 06:44 PM
Same hubs on both models, so the 1650 is a straight axle!  I have a bare axle on an MF14 diff, so I'll run out now & measure.
#6 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 17, 2013 - 06:48 PM
1 1/8" axles, with 1/4" keyway.  It would be super if they are the right OD!
#7 mjodrey OFFLINE
  • 2374 Thanks
  • 13481 posts
Posted January 17, 2013 - 07:09 PM
Sorry Daniel,I can't help you on that.
#8 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted January 17, 2013 - 09:17 PM
Its rainy and nasty now but I will measure mine when I can. I do believe they are 1 1/8 though and a 1/4 key way.
#9 Texas Deere and Horse OFFLINE
  • 15111 Thanks
  • 15570 posts
Posted January 17, 2013 - 09:35 PM
I will have to dig mine out, but I remember them being 1 1/8" just like the large C-series axle.
#10 Texas Deere and Horse OFFLINE
  • 15111 Thanks
  • 15570 posts
Posted January 17, 2013 - 09:48 PM
And they are yours my Friend if they are what you need. :thumbs:
