Am I Taking This Restoration Thing Too Far ?
i.d.plate restoration cub 72
49 replies to this topic
#46 83MALIBU OFFLINE
83MALIBU
  • 40 Thanks
  • 69 posts
Posted June 01, 2013 - 09:39 AM
Wow, very nice build. I wish I had your patience.
  • mike912e said thank you
#47 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted June 06, 2013 - 07:04 PM
Here are three pics of the new I.D. plate with the engraving done . It might be hard to read as the plate is new and there's no dirt in the letter/number grooves . The engraver replicated the size and font quite well . Added two more pics of the plate on the Cub's engine shroud .
Woops ! I realized that I had installed the wrong plate on this Cub ; K241. I have since installed the correct one on the old "72" ; K161. The engraver used an extra plate to sample the size and font and I grabbed it by mistake .
#48 lrhredjb OFFLINE
lrhredjb
  • 922 Thanks
  • 689 posts
Posted July 25, 2013 - 08:33 AM
I purchased the correct thickness aluminum sheet, sheared the plates to the correct size ( same as the original I.D.plate ) . Jigged the hole punch to put the correct size and location hole in each corner then filed the notch in the bottom edge . That was the easy part ! Next I contacted a local silkscreen printer and had them produce an exact reproduction of the printing on the plate . Then they printed it onto the aluminum plate and now all I have left to do is procure the correct size metal stamp set and transfer the serial number and spec numbers over to the new plate . I saved the original three-eared fasteners that were on it originally but am considering using 1/8" pop rivets instead . I'm also making sure that the throttle and choke cables don't come anywhere near the new plate . And yes, I did make extra plates if anyone's interested . It just takes time and patience and lots of money !
Nice job on the tag. I'm always amazed how well some people can replicate things. BTW a good source for tag stock is a IN state license plate. For several years now they have been made from flat aluminum stock that is real close to the thickness of tags. The back side of the plate is mill finish so no prep work needed. The new tag can be attached using drive screws which is a kind of rivet with a steep pitch thread on the shank.It is simply driven into a hole.  Commonly used to fasten tags on electric motors and machines. McMaster Carr catalog would list them. You are raising the bar for restorations awfully high you know. :bounce:
Larry
#49 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,298 Thanks
  • 10,283 posts
Posted July 25, 2013 - 10:04 AM
It's your time and money, do you think it's going too far?
#50 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted July 25, 2013 - 11:58 AM
Thanks for your comments, everyone .
   This fall I will start restoring my 124 Cadet and based on my experience with my first one ( CC 72 ) I hope it turns out even better . I guess all this attention to detail comes from working in the aircraft building business for thirty years . It has to be done correctly !
Hope to see some of you at the Dover show next month .
Mike
Also tagged with one or more of these keywords: i.d.plate, restoration, cub 72
