Grille
john deere 314
2 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 16, 2013 - 11:41 PM
I have read where the grille on some of these 300 series tractors are a pain etc .
I agree completely , so I was getting ready start sanding on mine tonight and I had a thought.
Take a 1/4" rod and lay full length behind each bar and tack into place .at each end and cut the 2 outside ones off and move in 1/4" and tack into place.
This I believe would stop the bending every time you have to remove grille and stop the rubbing on the side panels . The grille woulld still look good .
I'm still thinking on the mounting system though , for a better way
Any thoughts?
larryd
  • jd.rasentrac said thank you
#2 JDBrian OFFLINE
  • 9,608 Thanks
  • 14,144 posts
Posted January 17, 2013 - 06:46 AM
Good idea Larry. If it was mounted to the front plate at the bottom using a rod or 2 pins then it could hinge down to access the pto. When I reassemble my 317 I'll have a shot at changing it to something better. It'll be a while before I get to that point.
  • larryd said thank you
#3 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 17, 2013 - 10:08 AM
That's is a thought. I'm going to take another look today at the mounting. If I do the rod thing , I need to look at doing the mount at the same time .
larryd
