Plowed With 18/6 Today
8 replies to this topic
#1 Hugh OFFLINE
Hugh
  • 171 Thanks
  • 171 posts
Posted January 16, 2013 - 11:32 PM
Today I awoke to about 4" of snow, pretty heavy and wet, so I fired up the 18/6 and set to work. Currently have about 450lbs on the back between the weight box and wheel weights and tire ballast.
Video:
  • daytime dave, MH81, KennyP and 3 others have said thanks
#2 chris m OFFLINE
chris m
  • 3,316 Thanks
  • 4,047 posts
Posted January 16, 2013 - 11:40 PM
Nice! she sounds  great! And it did a great job on that wet snow!
We only had an inch of wet stuff and I have a dirt and rock driveway so it wasn't even enough to try and plow.
Glad you got some seat time and thanks for the video! That was great :thumbs:
  • Hugh said thank you
#3 Cat385B ONLINE
    Therapy CAT
  • 12,969 Thanks
  • 9,524 posts
Posted January 17, 2013 - 12:32 AM
Lucky duck. Pat, I'd like to buy a 'snowflake'. Our drought continues...........
Thanks for the video.
#4 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 17, 2013 - 05:34 AM
lol....I have seen your driveway many times.  You have quite a few videos on youtube, didn't know you were a member here.  Recognized it as soon as is popped up.  Good job and at least someone is having fun with the snow.  We had a couple foot at once and now nuthing.......
#5 KennyP ONLINE
  • 34,253 Thanks
  • 43,378 posts
Posted January 17, 2013 - 06:40 AM
Great video, Hugh! Sounds like you have plenty of weight on that tractor.
#6 JDBrian OFFLINE
  • 9,596 Thanks
Posted January 17, 2013 - 06:51 AM
That does a nice job. Wheel weight is the best choice IMO. Too much in the weight box and you'll have trouble steering! Your current setup seems to work great.  We had about 5-6" overnight here. Light snow, not wet, for a change.
#7 MH81 OFFLINE
  • 29,937 Thanks
  • 29,753 posts
Posted January 17, 2013 - 08:21 AM
Fun vid, thanks for letting us play along. Being out on the road some, have you thought of a blinky light of some kind?
#8 Hugh OFFLINE
Hugh
  • 171 Thanks
  • 171 posts
Posted January 17, 2013 - 08:32 AM
Yeah I am pretty active on youtube, I figure pictures only can only do so much :)
I was having slipping issues before adding the weight box (~225lbs) because the wet snow causes the ground to be real wet, powerdy snow doesnt, and this thing will rip right thru that. Steering isnt too bad, I have a set of tri ribs, thats what I should really use.
I have, but the style of plowing I use where Im in 3rd hi all the time half throttle or higher and just ram into things, I would need a pretty sturdy blinky light mount. I had one on my first tractor, an 8XL (I have a video where you can see it) and it didnt work as planned. I keep all my lights on the 19.9 cause for one its harder to see cause its not yellow, and that machine gets used in a lower gear, and in case I ever did need to get out of the way of a car, plow, etc, the 19.9 is much less nimble than the 18/6.
Thanks for the nice comments, fellas
#9 daytime dave OFFLINE
  • 4,624 Thanks
  • 6,438 posts
Posted January 17, 2013 - 09:14 AM
That set up looks like it works very well.  Thanks for the interesting video.  I'll have to check more on You Tube.
