How Do I Clean My Jd Seat?
15 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted January 16, 2013 - 08:30 PM
the seat on my gt 275 is starting to turn balck form not being taking care of for a  long time. what products do you guys use to bring old seats back to life??
#2 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted January 16, 2013 - 08:36 PM
Greg,
Try using a majic eraser, made by Mr. Clean. If that don't work, go over the seat lightly with a little rubbing compound, then armoral.
  • Alc and JRJ have said thanks
#3 JDGuy445 OFFLINE
JDGuy445
  • 356 Thanks
  • 428 posts
Posted January 16, 2013 - 08:46 PM
I found take just a tiny bit of a product called "Gum Cutter" put it on a towel and rub it over. Magic erasers work as well.
#4 Robert Webb OFFLINE
Robert Webb
  • 907 Thanks
  • 429 posts
Posted January 16, 2013 - 08:58 PM
Mold/Mildew Bathroom cleaner............spray on, let it foam and rinse it off.
#5 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted January 16, 2013 - 09:00 PM
thanks guys for the tips
#6 Mitchell Cain OFFLINE
Mitchell Cain
  • Validating
  • 48 Thanks
  • 54 posts
Posted February 13, 2013 - 03:29 PM
I use white wall tire cleaner and a soft brissel brush then wash off with water.
        Works great
  • backwoods said thank you
#7 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted February 13, 2013 - 04:47 PM
WD-40 works on many things. The real secret on anything you use is, put it on and let it stand, wipe and repeat til grime is gone.
#8 grnspot110 ONLINE
grnspot110
  • 4,161 Thanks
  • 2,649 posts
Posted February 13, 2013 - 08:06 PM
How about rust stains?  The 56 RER I bought last Fall has old rust staining on an otherwise good yellow seat cushion.  Haven't tried anything yet, but the 56 is my next project.   ~~  Lowell
#9 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted February 13, 2013 - 09:13 PM
Lowell,
I'd try the majic eraser first, and see how that does. I was going to recommend some CLR, but I don't know if that will bleacher the vinyl or not. Oxy Clean might work, but again, I don't know if it will bleach it or not.
I experiment with a lot of different cleaners and products on various types of items, but removing rust stains from vinyl is one that I haven't tried yet. I should buy some old used seats off of ebay when they are aren't worth anything, just to have something to practice on. A couple bucks for an old worn seat wouldn't be much of a lose if it gets ruined. Too bad I never kept any of my old seats that I replaced.
#10 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,366 posts
Posted February 15, 2013 - 09:28 AM
Soft Scrub with Bleach is an option to consider.
#11 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 15, 2013 - 10:36 AM
i got it all cleaned up ill post up some pics later. i used this stuff called tuff stuff and some 3m plastic cleaner it looks great now compared to what i started with
#12 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 15, 2013 - 01:04 PM
here it is before i started to clean it
and here it is after i cleaned it
  • jd.rasentrac said thank you
#13 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,477 Thanks
  • 5,772 posts
Posted February 15, 2013 - 01:37 PM
Nice!!
#14 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted February 15, 2013 - 11:32 PM
it took a lot of scrubbing but im happy with the way it turned out
#15 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted February 16, 2013 - 06:59 PM
You did a super good job of cleaning the seat, how long did it take you. You are luck it has not got any tears or rips in it which seem to have a habit of doing.
Dick
Edited by JRJ, February 16, 2013 - 07:00 PM.
