Whats Difference Between Gt And Ff 18?
carftsman gt18 ff18
12 replies to this topic
#1 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted January 16, 2013 - 02:23 PM
What's the difference?
#2 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted January 16, 2013 - 02:42 PM
I dont mean to be rude, but there are several discussions on this site about that subject. I dont think I can remember all of the highlights to list them here. You could do a search on that while you are waiting for replies on this post
  • CubHorse80 said thank you
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 16, 2013 - 02:44 PM
I think it's mostly size, as in bigger frame, wheels tires etc. The FF's were conceived to compete with the other Super GT's specifically the JD400. I'm not sure how much stronger the tractor would be in terms of pulling power but it is heavier and has larger tires.
#4 KennyP OFFLINE
  • 38,231 Thanks
  • 45,866 posts
Posted January 16, 2013 - 04:53 PM
I have both, a GT18 and an FF20. The Gt18 is a nearly a wimp compared to the FF20. The FF is heavier (thus more tractive power), has hydraulic lift, a more substantial rear axle, bigger rear tires (again for more traction and pull). All-in-all, just a heavier version built to do more than the average GT.
#5 CubHorse80 ONLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted January 16, 2013 - 05:36 PM
The ff's are hydro too right?
#6 KennyP OFFLINE
  • 38,231 Thanks
  • 45,866 posts
Posted January 16, 2013 - 05:54 PM
Yes.
#7 CubHorse80 ONLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted January 16, 2013 - 06:53 PM
what about power steering? i have the gt18 and wondering if i should get a ff18. but only of its worth it. I dont need 2 of the same tractors
#8 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted January 16, 2013 - 06:57 PM
The FF 18s dont have power steering, but the angle of the spindles make turning real easy even with a front blade. I mounted 160# of ballast weight on the front of mine to lift more weight with the 3 point and it still steers easy
#9 KennyP OFFLINE
  • 38,231 Thanks
  • 45,866 posts
Posted January 16, 2013 - 07:01 PM
Try that with a GT18!
#10 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted January 16, 2013 - 07:09 PM
I didnt have a GT18 handy to compare the FF to. This is a cub 122, the hood is smaller but the wheel base and hood height are real close.
#11 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted January 16, 2013 - 07:24 PM
i have 270 lbs of weight in tires and its a b**ch to turn! i have to use my whole upper body! I got the plow in, along with amber strobes
#12 KennyP ONLINE
  • 38,231 Thanks
  • 45,866 posts
Posted January 16, 2013 - 07:26 PM
I thought I had a pic with the GT18, but only the ones next to the LGT 165:
The Ford weighs nearly the same as the FF. But it's a lot smaller.
#13 CubHorse80 OFFLINE
CubHorse80
  • 159 Thanks
  • 318 posts
Posted January 16, 2013 - 07:29 PM
Pics with plow. those leds on grille are strobes, i will try to get video up...
Also tagged with one or more of these keywords: carftsman, gt18, ff18
