Cleaning Tank
12 replies to this topic
#1 twostep ONLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,535 posts
Posted January 15, 2013 - 11:49 PM
Been wanting a mineral spirits cleaning tank for a while but was holding off on spending $80-120 on one... well the old man calls me up last week and asks if I want one. It's not a fancy one with a circulation pump but that is something I can add later if I want. This thing has been in my dad's shop and then barn for 30 years or
better. I had to scrape an inch of sludge out of the bottom but she is ready for work now!
#2 Nato77 ONLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted January 16, 2013 - 12:06 AM
I can't count how many parts washing half barrels I've seen though the years. Looks like someone did a real nice job making it.
What were you going to use for washing solution?   Mineral spirits?
  • twostep said thank you
#3 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 16, 2013 - 02:41 AM
Can't beat the price and that was made nice! Congrats on getting it :thumbs:
#4 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted January 16, 2013 - 04:39 AM
Looks in great shape for it's age. Just be sure to keep open flames away from where you put it!
#5 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 16, 2013 - 08:48 AM
That looks like it will get the job done. I'd also be worried about fumes and the fire hazard with such a large surface area of solvent exposed.
#6 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted January 16, 2013 - 08:55 AM
NICE!  Even has a shelf to keep brushes and scrapers and stuff without having them drip all over the floor or your work bench.  ( like those of us who use 5 gallon buckets or dishpans for parts cleaning)
#7 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted January 16, 2013 - 09:00 AM
:nothingtoadd:
#8 twostep ONLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,535 posts
Posted January 16, 2013 - 09:51 AM
Yeah, my dad is an automatic transmission mechanic and has been for 50 years now. Back in those days they made a lot of their own tools and equipment... and they did it right! Yup, mineral spirits is what I use to clean greasy/oily parts.
Yeah, I don't plan to keep cleaning solvent just sitting in it since I'm not going to be cleaning parts regularly. I'll clean parts and then drain the solvent back into the jugs/cans for storage. As far as fire hazard, the lid fits pretty tight and should work as a fire suppressor plus I keep a large fire extinguisher handy in my garage. I put a few parts and about a gallon in last night (had to prop up one end to keep the solvent at one end of the tank) and I didn't smell any in the garage this morning so we'll see.
Yeah, it's built right. Just need to put a drain valve in one end so I can easily drain solvent into a bucket. I've been using buckets and plastic tubs for a while so I'm happy to have this now. Plus the flat top can be used as a table when I'm not cleaning parts!
  • Nato77 said thank you
#9 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted January 16, 2013 - 10:15 AM
A nice addition to the shop as well as a piece of family history..
#10 TAHOE ONLINE
TAHOE
  • 7,972 Thanks
  • 5,673 posts
Posted January 16, 2013 - 10:23 AM
That is pretty well built and your dad's. I gave a parts washer away many year ago, regret it now.
I wouldn't worry too much about using mineral spirits, it has flash point of around 135-140* so unless you are heating the tank, shouldn't get too many flammable vapors. As you said, you have extinquisher and just keep no open flames or heat sources around. We use spirits regularly here at work to clean up printing inks/pigments in our labs after we test it.
#11 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 16, 2013 - 02:32 PM
i would use a Alkaline cleaner such as Spray 9 or mean green and water have a fish tank heater in the liquid no worry's of Fire and its safer does a better job IMO you just need to dry your parts off after Tho
#12 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted January 16, 2013 - 06:43 PM
Nice tank!  Just throwing my 2 cents out there,   in case of fire, close the lid first, the fire extinguisher may blow the solvent out spreading the fire. Keep the lid closed when you are not using it to slow evaporation and saving you money on refills. I bought a cheapy 5 gallon parts washer and the pumps only works when it wants to and the wiring was messed up when I got it new. I never really trusted it after that. Its nice to have a flooded brush to clean stuff off with, but I dont think it's worth the fire hazard.  sloshing parts around in a half full 5 gallon bucket works just as good (as long as they fit)
#13 twostep OFFLINE
twostep
    Rockstar
  • 1,983 Thanks
  • 2,535 posts
Posted January 16, 2013 - 11:24 PM
I've used "degreasers" and I've never been impressed with them... maybe I'm just not using the right ones. I grew up around a transmission shop so mineral spirit is all I know... other than the newer parts cleaners that use really hot water with water based detergents. They do a great job, that is for sure. I wonder if you could use an old dish washer as a parts washer...
