Red 682 & 44c Rebuild
74 replies to this topic
#61 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 06, 2013 - 08:11 AM
Looking great!!! Thanks for the updates.
  • twostep said thank you
#62 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 06, 2013 - 04:55 PM
Here is the new schematic for the mower. I'm mounting up some back up LED back up lights on the light circuit. Drawing this up also reminded me that I didn't fuse the relay circuit. I'll add in another 10 amp fuse between the solenoid supply and the relay.
Edited by twostep, March 06, 2013 - 04:56 PM.
#63 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted March 06, 2013 - 06:59 PM
Looks really nice. Just let me know when I can come pickup and break it in for ya, should only take 2, maybe 3 summers :big_hug:  :bigrofl:
I actually passed on a 682 hydro with no motor. I always wanted to get into pulling and I know hyrdro not the best, but should've bought it anyway.
#64 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 07, 2013 - 12:28 PM
Tahoe, you're a funny guy.
I finished up the wiring including some nice LED rear backup/work lights. I'll get pictures up tonight. Fuel tank is cleaned out and put back on. I bet I dumped a 1/4 cup of trash out of the tank. Luckily the valve that attaches to the tank has a mesh screen on it. I also got the rear and side tin's back on. Seat bolted up and changed the oil. I've got a front light bulb burnt out so I need to pick one of those up.
Front right tire leaked down so I sprayed it with soapy water and saw that it was leaking all the way around the rim. I pumped it up to 30psi (I was scared to death) and bounced it around a few times and it stopped leaking. I guess the bead just hadn't seated all the way. We'll see if it holds.
I hope to get the deck hanger mounted up tonight tonight. And once my tie rod ends come in I'll take her for a test drive and try out the deck.
#65 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 07, 2013 - 01:17 PM
LOL. I have had that feeling more than once when trying to get a bead to seat. Glad you got it fixed. :thumbs:
#66 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 07, 2013 - 10:49 PM
She is put back together... minus the deck pully cover, I'm going to wait on that until I get to test it out. I also pulled out the deutz frame. I need to get it togther so I can move it. This thing is heavy... If I had an engine I think it would make a great base for a loader.
Edited by twostep, March 07, 2013 - 10:51 PM.
#67 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted March 08, 2013 - 06:44 AM
Looks real good. I was trying to figure out the first pics then saw in the fourth they were the lights. Should work well!
#68 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted March 08, 2013 - 08:01 AM
That came out great. You did a nice job on it :thumbs:
#69 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 08, 2013 - 09:08 AM
Thanks guys. A good bath and a new seat and the ol'girl will be like new... almost. I The deck from outside to outside is only off by about 3/16" so I'm happy with that. I have to drop the deck back off to put the belt on so I might adjust the hangers slightly.
#70 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 19, 2013 - 11:01 PM
Got a chance to get back on this tonight. I had an electrical issue and didn't have time to investigate... turns out the safetly relay was no good. I fixed that and we are in good shape now. I plan to test mow and adjust the deck this weekend.
#71 jpackard56 OFFLINE
jpackard56
  • 1,837 Thanks
  • 1,434 posts
Posted March 20, 2013 - 09:27 PM
Nice job Bobby, I never saw this thread till tonight, followed the whole process, looks like she should serve you for a long time and look good at the same time!
#72 56series OFFLINE
56series
  • 31 Thanks
  • 31 posts
Posted March 21, 2013 - 06:51 PM
Very nice job! I have the same problem you have. I just don't know when to stop! :loosing_it:  Am in the middle of a 1650 resto, that began as a Hydro rebuild. Ooh well.
Nice Job
Jason
#73 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted March 24, 2013 - 12:24 AM
I think I have a problem... I'm waiting on a consdenser and I decided to replace a few more of the stock wires...
#74 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted April 22, 2013 - 10:10 AM
Replaced the points, condenser, and plugs and she fired right up. It is running rich though so I've got to figure out why. I adjusted the mower deck and got it pretty level. Mowed with it on Sunday and I'm happy with it. Does a great job and has plenty of power. I still plan to use the kubota and finish mower for the large portion of the side yard but this thing does great for the trim mowing and the smaller areas. I need to add a steering wheel knob.
#75 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted June 20, 2013 - 09:48 PM
Sold the Cub today... bittersweet. I loved this mower. I believe it's going to a good home. And I've not got funds for my FEL!!!
