Red 682 & 44c Rebuild
74 replies to this topic
#46 twostep OFFLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted February 26, 2013 - 11:22 PM
I got the rear axle bolted back up, and filled. I wished I had the time to do a full frame off restore but I need to get this thing out of the middle of the floor so I can get my seeds starting table set up.
  • Texas Deere and Horse, KennyP and CRFarnsworth have said thanks
#47 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted February 27, 2013 - 12:43 AM
Bobby, That is really coming along nicely. I can't wait to see it all back together. Nice job!
#48 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted February 27, 2013 - 06:17 AM
That is looking good, Bobby!
#49 twostep OFFLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted February 27, 2013 - 08:22 AM
Thanks guys. I hope I can get a decade or two of mowing service out of this thing.
Last summer this thing would increase spead while going down hill so. It's missing the spead control knob so I would alwasy just keep a hand on it, anyway this thread: http://gardentractor...he-hydro-pumps/ led me to think that the creeping speed was due to a worn trunion. So while I had the rear end apart I inspected the trunnion parts and they have no visiable wear on them. If I didn't know better I would think they were new.
#50 Trav1s ONLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted February 27, 2013 - 08:49 AM
Nice work B!  I too love the x82 Cubs.
  • twostep said thank you
#51 TAHOE ONLINE
TAHOE
  • 8,337 Thanks
  • 5,819 posts
Posted February 28, 2013 - 10:16 AM
Since you don't have time for it, give me your addy, Berea is only 2 1/2 hrs south. I will come pick it up and finish it for you, ...did I forget to mention it takes me like 10 yrs to do one :smilewink:  :D
looking good. I so have to get my Sears back together!!
#52 twostep OFFLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted February 28, 2013 - 04:43 PM
haha, I know the trick you are trying to pull!! No chance! Besides I've got to leave something to do a couple of winters from now! Unless she sucks down the fuel too bad, this girl's going to pull mowing duty this summer so I've get her operational.
I got the rear tins back on last night and went to fire it up but it wouldn't do anything so I dug up the wiring schematic today and will check it out tonight. The spring bar that is on the brake pedel rock shaft broke so it might not be pushing the safety switch in far enough.
#53 TAHOE ONLINE
TAHOE
  • 8,337 Thanks
  • 5,819 posts
Posted March 01, 2013 - 10:23 AM
Worth a shot, can knock a guy from trying  :smilewink:  :D
#54 twostep OFFLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted March 01, 2013 - 11:26 AM
Well I've eliminated all of the safety switches except the PTO/safety switch... it doesn't seem to be operating according to the schematic that is attached.
I am also cleaning up the wiring considerably; eliminating the reverse/PTO relay, the seat safety switch and and puting some protection in areas that didn't previously have.
#55 twostep OFFLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted March 01, 2013 - 10:51 PM
I hate when I have to take things back apart... :wallbanging:
Got the wiring figured out. Eliminated the reverse relay and the momentary starter safety/PTO switch took a crap on me... odd that it happened when it did but once I wired around it I got fire again. I'm going to replace it with a SPST and add a push style momentary safety elsewhere. PTO is wired through a relay that can only be activated while the key is on. This will keep me from starting when the PTO engaged and it will keep an engaged PTO from draining my batter.
So wiring is figured out:
:bigrofl:
Luckily I'm an engineer for an automotive wiring company :smilewink:
#56 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted March 02, 2013 - 04:56 AM
I have had 2 of those style PTO switches mess up like that. Probably corrosion inside!
#57 daytime dave OFFLINE
  • 4,986 Thanks
  • 6,611 posts
Posted March 02, 2013 - 11:00 AM
Sure looking good so far.  Nice work.  :thumbs:
#58 twostep OFFLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted March 03, 2013 - 11:43 PM
Got the wire finished up today. I'll work on the new modified schematic tomorrow.
I moved the solenoid to the front, no need in having extra wires running the full length of the frame. Now only a large power wire and one wire for the tail lights run to the back. I'm going to rig up a set of switched backup lights after I get down with all of the manditory stuff. Here is the 60amp (more than I need but all I had in stock and way less than the fuse max on that large wire) close to the battery:
These are a couple of improvments on the wires that went through the "firewall" to the coil, pto, starter and headlights. I added some protection and cleaned the routing up a bit:
Another spot that need some upgrade:
I installed the nw switches. The PTO switch is just a standard SPST switch and the one down below (where a broken fuse holder was) is the momentary safety switch for the starter. This will keep you (or a child) from just reaching over and starting the mower. These switches are out of a Peterbuilt that my FIL's company was junking. They are heavy duty:
The bat + wire and the starter wire are held in place by a sheet metal style tie-band clamp:
The new wiring layout, note the new relay, the absence of the reverse relay, and the new starter relay location.
My little helper, she loves to be out in the garage with me!
And like I mentioned before... I have a hard time stopping when it comes to tearing down:
  • LTD said thank you
#59 KennyP ONLINE
  • 41,503 Thanks
  • 47,416 posts
Posted March 04, 2013 - 05:40 AM
Looks like some great help you have there! Wiring is looking good!
#60 twostep OFFLINE
twostep
    Rockstar
  • 1,990 Thanks
  • 2,541 posts
Posted March 05, 2013 - 11:22 PM
Front axle is back on. Steering box is tightened up. Waiting on new tie rod ends to get the steer linkages put back on. This old girl is going to be smooth this summer.
