318 Continental Repower
15 replies to this topic
#1 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 15, 2013 - 09:15 PM
this is a new topic that i started in a different topic.
 http://gardentractor...john-deere-318/
so what i have is a 318 with a kohler k301 in it, which seems under powered. so what i am attempting to do is put a continental f 206 straight six into it, now this motor doesn't run yet but will soon  the motor is a crank start, if i could find a fly wheel and a starter i could switch it.
so far i know i will have to extend the frame some, exact measurement isn't known at the moment.
when i get this running and driving i will hock up the pump and get the blower working to see how good it works. 005 - Copy (2).JPG 006 - Copy.JPG 007 - Copy.JPG 012 - Copy (2).JPG 016 - Copy (2).JPG
for sitting for who knows how long it is actually really clean and tight on the inside
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted January 15, 2013 - 09:20 PM
Won't that be to heavy for the type of front axle on the 318?
Will be interesting to see the progression on your build. Good luck :thumbs:
#3 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 15, 2013 - 09:28 PM
i don't think it will as these are able to have FEL on them
  • chris m said thank you
#4 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted January 15, 2013 - 09:58 PM
The axle should hold up just fine.
Unless you hit a chuck hole at full speed.
Power steering is a great feature of a 318.
#5 8tyman8 OFFLINE
8tyman8
  • 416 Thanks
  • 731 posts
Posted January 15, 2013 - 11:07 PM
I would sell (or trade) that engine for a 2 cylinder onan or briggs but if not it would be a neat repower
#6 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 15, 2013 - 11:34 PM
i was thinking smaller but this is what i found and besides no one, that i know of, has a gt with a straight six
#7 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted January 16, 2013 - 02:58 AM
That will be a real 1 of a kind! Thanks for sharing.
#8 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted January 16, 2013 - 01:19 PM
Ill be watching this... Ive been thinking of putting an opposed Onan or Brighs Vanguard in my 140 once the K321a gors out.
#9 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted January 18, 2013 - 11:30 PM
well so far i have managed to track down a distributor that i will hopefully be able to use. now i am just waiting on that to get here.
#10 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted February 04, 2013 - 11:23 PM
im still waiting for parts for this thing, so i might go talk to a friend about a 4 banger teats in a Chevy luv that he doesn't use any more
#11 ajcan OFFLINE
ajcan
  • 77 Thanks
  • 55 posts
Posted February 06, 2013 - 09:44 AM
There is a guy on weekendfreedommachines that does odd builds like this.If someone else can remember his name maybe they can chime in.I figured if you need help with something maybe he could offer some advise.He has done a boat motor and a couple other things.I like custom builds.That poor 318 needs some muscle.LOL.
AJ
#12 Trav1s ONLINE
Trav1s
  • 3,585 Thanks
  • 4,561 posts
Posted February 06, 2013 - 10:32 AM
I am pretty sure you are talking of Bill Schwab who is in the Cincinnati area.  I forget his user name over there.
#13 ajcan OFFLINE
ajcan
  • 77 Thanks
  • 55 posts
Posted February 06, 2013 - 06:06 PM
Thats it.
#14 olcowhand ONLINE
  • 42,902 Thanks
  • 31,943 posts
Posted February 06, 2013 - 07:10 PM
If you plan to drive the hydro off the flywheel end, it will be turning the wrong direction of rotation.  To do this, you just rotate the charge pump 180 degrees, and you are supposed to take the pump apart & put slots in the valve plate opposite of where they are factory.  Some don't do the slot thing & still have good results.  Driven off the pulley end, it requires no changes at all to the hydro.
#15 nbent OFFLINE
nbent
    customizer
  • 678 Thanks
  • 539 posts
Posted February 06, 2013 - 10:50 PM
yah i though about that today as was looking at it, so im going to look at an engine in an old chevy luv to see if it will work without to much work on the hydro
Edited by nbent, February 06, 2013 - 10:50 PM.
