Cub 1450 Hydro Fill/ Tank
hydro cub cadet 1450
3 replies to this topic
#1 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted January 14, 2013 - 02:43 PM
Where do i check hydro fluid level and fill? in a cub 1450. it is throught that top cover held on by 4 bolts?
#2 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 14, 2013 - 06:15 PM
The oil fill and check are 2 in one. There is a plug about halfway up the back plate on the rearend. Fill through this plug till it starts running out.
#3 CubHorse80 OFFLINE
CubHorse80
  • 162 Thanks
  • 318 posts
Posted January 14, 2013 - 07:27 PM
just with hydro fluid?
#4 IHCubGuy ONLINE
IHCubGuy
  • 1,611 Thanks
  • 1,638 posts
Posted January 14, 2013 - 08:29 PM
It should have IH Hytran fluid in it.  If you don't want to use their brand then you need to get hydraulic/transmission fluid.  I reccomend the regular IH fluid from a CaseIH dealer as the OEM fluid used in them is formulated to absorb water better than the generic fluid you get at Napa or TSC.
Also tagged with one or more of these keywords: hydro, cub cadet, 1450
