Axle Pivot
jd314
13 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 13, 2013 - 12:16 PM
Quick question ?  Has anyone ever tried putting a grease zerk in the axle for the pivot bolt ?
Seems like it would be a good thing. If I remember correctly my 917H had one on it.
Any thoughts.
larryd
  • ol' stonebreaker said thank you
#2 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted January 13, 2013 - 12:23 PM
There is one on my Cub 129. They should all have one, but that does not mean they do. You can always put one in.
Geno
  • larryd said thank you
#3 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted January 13, 2013 - 12:28 PM
I think it would be a good idea to be able grease the axle pivot. Just make sure where you locate the zerk fitting it doesn't interfere with the pivot of the axle. Remembering to grease said fitting is the next hurdle. :say_what:
#4 Trav1s OFFLINE
Trav1s
  • 3,648 Thanks
  • 4,603 posts
Posted January 13, 2013 - 12:52 PM
RF's have them and my 120 has a grease zerk on the pivot.
#5 wawcub47 OFFLINE
wawcub47
  • 68 Thanks
  • 167 posts
Posted January 13, 2013 - 01:32 PM
my gravely has one!
#6 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted January 13, 2013 - 02:15 PM
Larry, some people will drill a hole down through the pivot bolt and then cross drill it at the correct spot(between the bushings) and install a grease fitting on the bolt head. That way you are not drilling and tapping cast iron. You could also drill the axle as well. Worn bushings and slop in the front axle are common problems on the 300 series. You can adjust out a lot of it by tightening the pivot castle nut until the axle just starts to drag when it pivots. This will help the new bushings last longer. It needs to be checked periodically to make sure it's still tight. A grease fitting should have been on the axle from the factory.
  • larryd and JRJ have said thanks
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 13, 2013 - 02:49 PM
Any thoughts.
larryd
  Good point, Larry. I'll do that to mine this summer. Another ?. Is the axle cast iron or cast steel?
                                             Mike
#8 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 13, 2013 - 03:42 PM
I like the idea of the zerk in the bolt if it wouldn't weaken yhe bolt to much . I know it would be easier for me to drill the axle though .
A decision to be made , I do have a small drill press so I might be able to do it . I think will expermint on another bolt first. I agree that it should have done at the factory. I've seen a lot of things done in field that the factory should have done called supplements (after thoughts ) that people like us have brought to their attention.
Thanks for the input guys
larryd
  • JRJ said thank you
#9 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 13, 2013 - 03:46 PM
Mike I believe the axles are cast iron.
larryd
Edited by larryd, January 13, 2013 - 03:47 PM.
#10 grnspot110 ONLINE
grnspot110
  • 4,340 Thanks
  • 2,702 posts
Posted January 13, 2013 - 04:09 PM
I've drilled the bolt on some tractors, easy to grease from the front!  ~~  Lowell
#11 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 13, 2013 - 09:10 PM
Ok. I practiced on an old bolt and done ok.
So I drilled the pivot bolt , put a zerk in it installed the axle and greased and works great.
Although a person could drill the axle with out taking the axle out and install a zerk in it if they wanted to .
larryd
#12 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 14, 2013 - 05:40 PM
Thanks Larry for posting the info., I will have to check mine out and see what i have.
Dick
#13 grnspot110 ONLINE
grnspot110
  • 4,340 Thanks
  • 2,702 posts
Posted January 14, 2013 - 07:49 PM
After I got to thinking about this, I've done both the axles & bolts on different tractors!  Both ways work fine.  ~~  Lowell
#14 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted January 14, 2013 - 07:53 PM
I'll be doing my 317 axle before it goes back in. Bought some fittings the other day. I need to get the king pin mounts reamed out and bushed at a machine shop as they were worn about 25 thou.
Also tagged with one or more of these keywords: jd314
