Dash Light Questions On My Gt275
5 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,629 Thanks
  • 2,818 posts
Posted January 13, 2013 - 10:31 AM
i picked up my gt275 the other night  and friday morning i put a battery in it to pull it im my garage and the red light was bliking. i know the one is the battery light but what is the one next ot it?? the red light.
here it is
#2 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 13, 2013 - 11:03 AM
 It blinks every time a Mom And Pop shop gets shut down by Deere :poke:  J/K :wallbanging:  may be a warning for a filter someplace??
#3 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted January 13, 2013 - 11:47 AM
Not familiar with the new machines, but could it be a low oil indicator?
#4 wawcub47 OFFLINE
wawcub47
  • 68 Thanks
  • 167 posts
Posted January 13, 2013 - 12:28 PM
Its the oil warning lite. mine will blink if its at low idle. I speed it up a little and it goes out. they are great lil tractors.
#5 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 13, 2013 - 02:12 PM
I also have the GT275 which is a good tractor. The one light like wawcub47 advised is for low oil. If you are using your tractor and turn the PTO on you may get the battery light if the rpm's are to low. If you are at full throdlle and still get the battery light you have a problem. first I would check the connection for the PTO which is down close to the PTO, you can take the plug-in connection apart and make sure it is clean. If that does not help you need to take the battery out and take it to an auto parts store and have them do a load test on it for you, most auto part stores will do that free. Lets stop at this point for now and see what you have.
Just make sure that all the electricial connections are making good.
Dick
#6 backwoods OFFLINE
backwoods
  • 2,629 Thanks
  • 2,818 posts
Posted January 13, 2013 - 06:33 PM
ok thanks for the tips guys ill check the oil either tonight or tomorrow. i was wondering if it i was an indicator to change the oil
