ariens loader trouble
13 replies to this topic
#1 00bluegtp OFFLINE
00bluegtp
  • 4 posts
Posted September 10, 2010 - 11:34 AM
I purchased an ariens 16h with a loader, 3 pt hitch, rear p.t.o..... Well whenever i try to lift the loder or bucket they wont go, but if i pulse the handles it will go ittle by little. I tried changing the oil but that didnt help at all.. Could this be air in the system. I need this thing to work... I have a a lot of mulch to move. please help. Also the weird thing is that the manual says to use 10w30. Thats what i used but it just seems weird. The loader even does it with no weight in it. Could it be there isnt enough oil?
#2 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 10, 2010 - 11:56 AM
If you changed the oil, then it should be full. Does this have a dedicated hydraulic pump, or does it share hydro oil & run off the charge pump? I'm guessing separate dedicated hydraulic system. It's possible the regulator bypass valve is stuck open.
#3 mjodrey OFFLINE
Posted September 10, 2010 - 12:01 PM
00bluegtp :welcometogttalk:glad to have you here.
#4 00bluegtp OFFLINE
00bluegtp
  • 4 posts
Posted September 10, 2010 - 12:43 PM
it has a sepperate pump on the front right side of the tractor and is engaged by the switch on the dashboard. where would i find that regulator valve? Is it in that valve body?
#5 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted September 10, 2010 - 01:35 PM
If I am not mistaken the regulator or pressure relief valve should be either right on the pump or right after it.
#6 00bluegtp OFFLINE
00bluegtp
  • 4 posts
Posted September 10, 2010 - 01:45 PM
hmmm... i wonder where it could be... ill check on the pump and in the hose on the way to the valve body.
#7 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 10, 2010 - 02:37 PM
It is likely in the control valve. Most times covered with an acorn nut.
#8 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 10, 2010 - 02:44 PM
Yep, usually, and sometimes it's just a big cap bolt (non adjustable type) with the psi setting stamped into the top of it.
#9 00bluegtp OFFLINE
00bluegtp
  • 4 posts
Posted September 12, 2010 - 10:55 AM
well i got it fixed.. It was this ittle belt that goes from the pto to the hyd. pump. It wwas shot, so worn out and dry rotted.
#10 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted September 12, 2010 - 11:26 AM
Good job, that makes for a nice easy cheaper fix.
#11 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 12, 2010 - 11:33 AM
So many times we bypass the obvious. Guess it's human nature to expect the worst. Glad it was an easy/cheap fix!:thumbs:
#12 massey driver OFFLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted September 12, 2010 - 12:07 PM
Easy,cheap, fixes are the kind of fixes I like for myself.Larry
#13 humpty OFFLINE
humpty
  • 1 posts
Posted September 13, 2010 - 08:51 AM
Hi 00bluegtp,
Do you have any pics of the 3pt on your Ariens?
I have a old New Holland that I'd like to buy/make a 3pt for and i was curious how yours mounted up.
Thanks,
humpty
#14 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted September 13, 2010 - 08:59 AM
Glad you got 'er fixed
Nice it wasn't a pricey fix.
