Oil Inside The Cylinder
3 replies to this topic
#1 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 11, 2013 - 05:01 PM
I finally figured out today why my Briggs and Stratton NPR-6 cuts off after about thirty seconds of running.
Somehow or another, the cylinder begins filling up with oil.  As well as the valve housing/adjustment.
The oil level is good.  I actually ran it a little lower than normal (3/4) to double verify.
I'm guessing I'll be facing a piston ring business.  It's strange that the oil control ring would go before a compression ring, since the engine has good compression.  The piston has 20 oversize stamped on it, so it's been bored once (or twice).  But before I go that much farther into the engine I thought I'd ask.
Since this is my first N series engine, does anyone know of any reason beyond a bad breather that would cause this issue?
Thanks!
Ben W. in VA
#2 DougT OFFLINE
DougT
    Dog Approved
  • 7,085 Thanks
  • 5,063 posts
Posted January 11, 2013 - 05:31 PM
I can't see an oil ring filling up the valve chamber. That sounds more like a breather issue to me.
#3 HDWildBill OFFLINE
  • 8,978 Thanks
Posted January 11, 2013 - 05:54 PM
I'm with Doug, it sure sounds like a breather issue.  Why do you say it's not?
Do a cylinder leak down test that will probably tell you where the oil is coming from.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 11, 2013 - 10:13 PM
Thanks gentlemen for your quick responses.
My assumption for the piston ring was that the amount of oil in the cylinder head would be hard to produce without a bad oil control ring.  But I've been wrong, and I certainly hope I'm wrong today since rings oversize are hard to come by for this engine.
The valve chamber is not excessive, although certainly present.
I will play with the breather and see what happens.
Thanks!
Ben W.
