Must Needed Tools For The Gt Enthusiast
157 replies to this topic
#61 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted January 12, 2013 - 06:08 PM
I've been following the thread remotely today and now am at a B&B with my wife but I have a few minutes while she naps to weigh in on the topic again.
Here are a few more for the list: soldering iron, anvil (for aiding in the persuasion of metal), large bench vice, grease gun and an inexpensive tachometer.
I'll add the new suggestions to the list once back from my night away with my lovely wife. Keep the ideas flowing.
  • HDWildBill and chris m have said thanks
#62 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 12, 2013 - 07:46 PM
A couple of those triangulated welding magnets.
A slab of brass to clamp under a hole that needs to be filled by puddle welding.
A flyswatter
A pair of twezzers
A rol of shrink wrap tape
  • Moosetales said thank you
#63 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 12, 2013 - 09:10 PM
When you get done filling my new custom GTtalk tool chest just PM me and I'll give you my the address so you can ship it to me :bigrofl:
#64 HDWildBill OFFLINE
  • 8,975 Thanks
Posted January 12, 2013 - 09:41 PM
The Idea of compiling a list for a Newbie is a good idea but this is such a comprehensive list that if I were a newbie and I saw a list like that I would probably say for get it.
#65 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted January 13, 2013 - 03:26 AM
Them magnets are a time saver for sure. Its nice to have a extra set of hands.
At the shop I took some used 3/4" copper pipe and hammered it flat to use as a backing for filling holes. Its a lot cheaper than buying one of those carbon blocks they sell.
#66 Michiganmobileman OFFLINE
Posted January 13, 2013 - 06:52 AM
Excellent idea for a thread and a great read through.  Lots of good ideas from the collective mind of you GTTalkers (as usual :thumbs:, go figure :smilewink: ).
I think everyone has the list pretty well covered but heres a few more (I dont think these were mentioned above)
A mirror on a stick comes in handy sometimes
Tapered steel punches to aid in aligning bolt holes
To go along with your jack for raising the tractor , wheel blocks or chocks for keeping the tractor in place
Dedicated oil drain pan
Funnels of various sizes
I have a couple big, old, non screw driving screwdrivers that I find work real well for an extended listening device.  I think the steel shank and plastic handle transfers the sound a little better than the wood dowel does.
Not really a "Tool" and mentioned before by Troy, but another use for cardboard:  keep some large pieces on hand too, they work great for throwing on the floor or ground before you lay down to look for that leak, I can slide around some pretty heavy stuff on the cement floor of the garage when sitting on a large piece of cardboard too.
Great idea for a thread, keep those ideas coming!!
Edited by Michiganmobileman, January 13, 2013 - 06:53 AM.
  • Moosetales and boyscout862 have said thanks
#67 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted January 13, 2013 - 09:51 AM
A flyswatter
A pair of twezzers
Hey "beep beep" (i.e. IamSherwood) glad to see you have you're new horn.
For us nubs would you be will to explain the use for the slab of brass a bit. I think I get it but would love to see your explanation.
Also, would love it if you all would add your favorite use for some of the suggestions; twezzers (what do you most frequently use them for), shrink wrap tape (how does that come in handy), etc. Thanks.
  • IamSherwood said thank you
#68 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted January 13, 2013 - 09:52 AM
SHIP IT? Forget that. I'm going to need to rent a semi and personally deliver it to you. BTW, I should have everything pulled together for you by weeks end.......don't I wish. :thumbs:
  • chris m said thank you
#69 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted January 13, 2013 - 09:54 AM
Maybe I need to break the list down into "Nub", "Experienced" and "Expert" type categories when we've compiled the mountain of tools we all use. Good suggestion. Wouldn't want any new prospects getting scared off from this GREAT hobby.
#70 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted January 13, 2013 - 09:55 AM
Okay, so I think I'm getting it. You guys use the copper and brass to stop the weld from "falling through" since the weld won't bond with the brass or copper?
#71 Moosetales OFFLINE
Moosetales
  • 1,088 Thanks
  • 1,284 posts
Posted January 13, 2013 - 09:59 AM
Speaking of the cardboard for the floor, in addition to using it to stay a bit cleaner, up here in Maine it's essential for use during the winter months so the floor doesn't SUCK the living heat out of your feet or body.
Has anyone tried out the low profile crawlers to see if they are low enough to use on a GT?
I'm a visual person so when you typed "I can slide around some pretty heavy stuff on the cement floor of the garage when sitting on a large piece of cardboard too" I pictured you sitting on a large piece of cardboard, in the middle of your garage, pushing a GT motor all around the garage floor all the while you are sitting on the piece of cardboard.
:bigrofl:
Edited by Moosetales, January 13, 2013 - 10:05 AM.
#72 Guest_gravely-power_*
  • Guests
Posted January 13, 2013 - 10:01 AM
BINGO!
#73 Alc OFFLINE
  • 6,885 Thanks
  • 7,461 posts
Posted January 13, 2013 - 10:06 AM
Yea , ,I use a piece for copper lug but any copper or I guess brass would work , here's a pic welding up a hole  .Al
#74 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 13, 2013 - 10:11 AM
The brass thing, I see you figured out.
Tweezers, are for picking up the dead flies that the swatter killed. :smilewink:  or stuff that might land in your paint job.
Here is a thread about shrink wrap tape. Just yesterday, I used it again, to tape a couple solid rubber tires
off a rototiller. Just layed down 3 pcs, forming a triangle in the middle, and then trimmed to expose the rim.
Soooooo much easier than masking tape.
#75 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted January 13, 2013 - 10:13 AM
Aluminum works too!
