58' Bolens Versa-matic Ignition Trouble (kohler K161)
107 replies to this topic
#106 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted November 24, 2013 - 11:27 AM
Are you getting a good, strong spark when testing from the plug wire toward ground (bypassing sparkplug) ?  ....The spark should be able to jump a 1/4" gap.
Measure the resistance of your sparkplug from the terminal to the center electrode.  .....Are you using resistor-type plugs?
Yes, a new magneto could be defective, or weak.   .....I don't remember if you replaced the armature, or just the coil.  ....Is the coil loose on the armature?  .....Does the coil have a good ground?
#107 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted November 24, 2013 - 09:17 PM
Ok, I finally have an update!
I decided to pull the plug and decrease the plug gap from the recommended specs, to see if anything would happen, and it started in one pull when I did that.
Could the mag I bought be defective? I dont see how the spark could be weak since all ignition components have been replaced.
It is certainly possible to get a bad one. Short of trying another one, I don't know how you'd be able to test it though, and they sure aren't cheap.
How much did you have to close the plug gap?
#108 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 25, 2013 - 07:14 AM
Its still able to jump the gap, the ignition tester I have shows the spark as being strong.
The coil is completely new with armature and everything.
