Springfield 36
22 replies to this topic
#1 William R OFFLINE
William R
  • 8 Thanks
  • 14 posts
Posted January 06, 2013 - 03:27 PM
I have a Springfield 36  i just aquired and I would like to know if someone could tell me where to find serial number it has steel fenders.  I know some of later models had fiberglass. Thanks Bill
#2 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 06, 2013 - 04:01 PM
All were made by Quick Manufactoring.  The models with plastic fenders were called Farmcrest.  You will find the serial number on a small tin tag that has a bolt running thru it.  It will be the 2nd bolt that runs thru the mount for the seat.  If its not there......it will be hard to tell but not impossible.  For example, my 1964 Springfield 36 says "64TE-6" which means its a 1964, Tractor, and the E means it came with electric start.  The "6" at the end means it came with a 6hp engine.
Here is a pic of mine......
If you have any questions about Springfields there are a few on here that collect them.  I know my fair share but the member that literally knows everything there is to know about Springfields is Casey (wvbuzzmaster)
  • William R said thank you
#3 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 06, 2013 - 05:06 PM
Post a pic and I will identify the year.
As for the fiberglass fenders they were on all of them, not just the Farmcrests.
#4 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted January 06, 2013 - 05:33 PM
wasnt the fiberglass fenders on the 64 and on up? If it has the original engine, check the serial number on the engine, if it is missing, pull the engine shroud off and look at the flywheel. should be cast there IF it is the original engine. I have 2 model 36's and a LT525. there are several knowledgablepeople on here that can help!
#5 pwombles OFFLINE
pwombles
  • 201 Thanks
  • 220 posts
Posted January 06, 2013 - 05:34 PM
And Pics would be great!
#6 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 06, 2013 - 05:47 PM
Mines a 64 and it has metal fenders which are original
#7 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 06, 2013 - 06:00 PM
Steel fenders and seat up through 1964. Fiberglass fenderpan for 1965 on.
#8 William R OFFLINE
William R
  • 8 Thanks
  • 14 posts
Posted January 06, 2013 - 08:06 PM
Thanks everyone. The seat and mounting spring are missing and I guess serial plate too. I'll do some more investigating. The engine might be original but the fuel tank is mounted on the engine  it had a starter at one time I see by the paint that it was taken off and still has a solinoid under dash. I'll try to put some pictures on . Thanks again everyone Bill
  • wvbuzzmaster said thank you
#9 dropped82 ONLINE
dropped82
    Nut Case
  • 2,493 Thanks
  • 1,816 posts
Posted January 06, 2013 - 08:41 PM
What brakes does it have? I know those changed through the years. Eric Sent from my SPH-D700 using Tapatalk 2
#10 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 06, 2013 - 08:44 PM
I taught all you guys well so far, don't lose your heads now, play it smart, wait for the pics LOL.
PS:
Only way I got so good at identifying these things is I buy em in bulk, and I wait for the pics I always request lol.
Edited by wvbuzzmaster, January 06, 2013 - 08:46 PM.
  • William R and dropped82 have said thanks
#11 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 07, 2013 - 05:00 AM
Casey.....this is where the healing begins.........lol
#12 mjodrey OFFLINE
Posted January 07, 2013 - 05:52 AM
Congrats on your Springfield 36.
#13 William R OFFLINE
William R
  • 8 Thanks
  • 14 posts
Posted January 12, 2013 - 09:43 PM
#14 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted January 12, 2013 - 09:46 PM
Do you have more than just the one picture? Any other angles?
#15 William R OFFLINE
William R
  • 8 Thanks
  • 14 posts
Posted January 12, 2013 - 09:48 PM
Yes I do but not smart enough to get them posted  no young people in the house lol
