Lucas Hydraulic Booster And Stop Leak !
4 replies to this topic
#1 8tyman8 OFFLINE
8tyman8
  • 414 Thanks
  • 731 posts
Posted January 05, 2013 - 08:46 PM
Well i have been looking and calling around town for this Lucas product (after i used the oil Stabilizer i was sold !) i called Napa Canadian tire ... and on nobody had it well after getting so metal for the 1256D project i stopped at Tsc sure enough it was there on the shelf  For 11 bucks ! got home and added some to my Bolens h14 (modded to the hill's with power steering aux hydraulics ) because the $75 worth of seals in the rear end are Seeping oil Again and it wines being a Eaton hydro i dumped 400 Ml (10+% )of the total volume started and lt run for a few minutes got on it drove it around the hydro does not sound all that bad its more responsive so is the steering and the Charge pump does not wine when using the steering and it is more responsive with the engine also driving it use to Surge now its smooth and Abit faster I do plan after i do plan to change the filter in the next 20 hours of running to Remove all the Gunk that its suppose remove I will post a up date after some running as i think it will need to get Hotter to clean it self out ! Till next time Keep your stick on the Ice
Cheers
Ty
#2 JDBrian OFFLINE
  • 9,594 Thanks
Posted January 05, 2013 - 08:52 PM
That's a nice product. Not sure if we can get that down here either.
#3 skyrydr2 OFFLINE
  • 3,697 Thanks
  • 3,318 posts
Posted January 06, 2013 - 05:54 AM
Its available at any Lucas dealer (TSC) along with many other products they sell.
#4 Michiganmobileman OFFLINE
Posted January 06, 2013 - 07:24 AM
Ty, what did the oil stabilizer do for you?
#5 8tyman8 OFFLINE
8tyman8
  • 414 Thanks
  • 731 posts
Posted January 06, 2013 - 03:19 PM
The oil stabilizer was used im my flat head briggs engine that has valve train noise (typical of that series of engine) the tick went away so after reading about the hydraulic booster i thought i would add it to my hydrostatic transmission that is the reservoir for the hydraulics (power steering hydraulic lift and Aux hydraulics )it makes a difference
  • Michiganmobileman said thank you
