Bean Cutlers At Home!
61 replies to this topic
#31 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 6041 Thanks
  • 2246 posts
Posted January 09, 2013 - 01:55 PM
Lets see if I can help you with the implement identification.
The cultivator tines that are mounted on it look correct but have different tool heads on them.
The tool  heads were changeable for tilling different types of crops.
The cultivator arms could be mounted to point forward or backward.
Here is what the manual shows.
The 3-gang disc look like they are the correct ones once you remove them from that frame.
This is how the manual shows them.
The plow looks like the right size but the shape of the main beam isn't right.
The drawing in the manual shows a "H" shape beam and the beam on the plow has flat sides.
Also the front mount for the colter disc doesn't look right and the mount to fasten it to the tool bar is way off ( from what I can tell from the drawing in the manual ).
Edited by jdcrawler, January 09, 2013 - 04:06 PM.
  • jim knutson said thank you
#32 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 09, 2013 - 05:17 PM
#33 jim knutson OFFLINE
jim knutson
  • 66 Thanks
  • 136 posts
Posted January 09, 2013 - 05:35 PM
hmmm....the plow looks close, but not quite. i see things that look the same, and others that are different :oh_shucks: guess i need to keep researching as it is not the same as Jerome's pic, or Ray's manual....
#34 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 09, 2013 - 06:33 PM
By my math J-32526 makes it the 6345 made Bean Cutler...
#35 jim knutson OFFLINE
jim knutson
  • 66 Thanks
  • 136 posts
Posted January 09, 2013 - 06:41 PM
does that mean the other one with serial J29738, is #3,557 made? thanks for the info.
#36 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted January 09, 2013 - 06:43 PM
im starting to like these bean cutlers and bolens ride-masters im going to get one when i find one
#37 jim knutson OFFLINE
jim knutson
  • 66 Thanks
  • 136 posts
Posted January 09, 2013 - 06:45 PM
thats what happened to me, after looking at old GT pics, i fell in love with them.
#38 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 09, 2013 - 06:46 PM
Looks like it to me.
Mine is J-26209 # 28 made. :D
#39 jim knutson OFFLINE
jim knutson
  • 66 Thanks
  • 136 posts
Posted January 09, 2013 - 06:47 PM
good pull there Jerome!
#40 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted January 09, 2013 - 06:59 PM
theres 2 ride masters on CL 60 miles from my house one they want 1,100 with 2 plows it says no pic and 1,250 no attachments. sunds high huh?
#41 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 09, 2013 - 07:04 PM
Yes they are.
#42 jim knutson OFFLINE
jim knutson
  • 66 Thanks
  • 136 posts
Posted January 09, 2013 - 07:20 PM
Ray, are those drawings from a manual you have? i asked Hank Watkins if he had any for sale for the Bean Cutlers, and he never said one way or the other??? i sure would like a manual for them.
#43 jim knutson OFFLINE
jim knutson
  • 66 Thanks
  • 136 posts
Posted January 09, 2013 - 08:08 PM
 i went out to get some magneto info, and to id the carb, when i noticed the tappet sidecover is missing :( . i unscrewed the oil drain plug, and only a trickle of water came out, but the oil represents gloppy goop. sooo, i got out the marvels mysterie oil in my squirt bottle, and gave the tappets, and springs a good soaking, then pulled the spark plug, and gave the valves and pistons a thorough soaking. hopefully by the time my gasket set and carb rebuild kit arrive, the mysterie oil will have worked it thing on all the internals i could get to. any suggestions on how i can flush the crankcase before  refill with oil and try to fire it?
Edited by jim knutson, January 09, 2013 - 08:08 PM.
#44 jim knutson OFFLINE
jim knutson
  • 66 Thanks
  • 136 posts
Posted January 09, 2013 - 09:14 PM
well it looks as though this engine has the flywheel shroud that allows the use of a generator....now i just need to find a generator and light, and i can drive it around at night! :D
#45 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 6041 Thanks
  • 2246 posts
Posted January 09, 2013 - 09:17 PM
Hank has copies of the FMC Bean Cutler manual for sale. That is where I got my copy from.
He also has "FMC" decals for the Bean Cutler.
Edited by jdcrawler, January 09, 2013 - 09:26 PM.
