Mf14/16 Lift Rock Shaft Bushings
5 replies to this topic
#1 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 04, 2013 - 03:25 PM
They sure look right.
That's the same as on the MF14 and 16 too, right?
#2 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 04, 2013 - 04:03 PM
CRAP....not for the 50/55 series, but for the MF14/16.  I will change my 1st post./  Thanks Will for jogging my dead brain!
#3 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 04, 2013 - 06:58 PM
I will have to check tomorrow to be sure on these.  I know the hydro control shaft is a different size ID, and they may be the 3/4" ID, with the lift shaft being 5/8" ID.  With these measurements, I can see if they will fit.  The ID can be machined out to 5/8" if needed.  I have an old MF14 frame with the lift shaft still in it to go by.
#4 esbbent ONLINE
esbbent
  • 537 Thanks
  • 357 posts
Posted January 05, 2013 - 08:52 AM
These bushings will fit the MF 14/16. When I did my 14 rebuild last year those are the same ones I used. Olcowhand is correct the lift shaft is 5/8", I just bought a 5/8" drill bit drilled them out and installed them back in the tractor. The only hard part is getting the old lift shaft out of the tractor, after a lots of PB blaster the brackets still wouldnt move on the shaft. I ended up prying the frame out far enough to get the lift shaft out and going to the press to get the brackets off.
  • olcowhand and HowardsMF155 have said thanks
#5 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 05, 2013 - 09:03 AM
Thanks esbbent....now I won't have to measure!  :thumbs:  I'm going to copy this to the Massey Parts page.
  • ducky said thank you
#6 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted January 05, 2013 - 09:23 AM
I stumbled onto these just doing an image search for an old Dynamark like Dad had when I was a kid.  These sure look like the same as the massey MF14/16 lift rock-shaft bushings.  If I remember right,  the MF ID is 3/4", so they may be a match.  They have the flat side & all.  They appear identical.  Here's the webpage link.
http://www.milfordpo...ings-s/1059.htm
R3303-1.jpg clear1x1.gifclear1x1.gifclear1x1.gifclear1x1.gifR3303 Flange Bearing Replaces Noma 54902 List Price: $3.93
Our Price: $2.50
Replaces AMF/DYNAMARK/NOMA 54902
Flange Bearing. Graphite Impregnated.
FLANGE OD:  1-9/16"
HEIGHT:  1/2"
OD:  1-3/8" Bullet_MoreInfo.gif
  • Moosetales said thank you
