Implement Lift Lever Button Replacement(mf10)..
11 replies to this topic
#1 77cjIN OFFLINE
77cjIN
  • 3 Thanks
  • 2 posts
Posted January 05, 2013 - 02:16 AM
Hi,
I'm new to the board, but have been browsing around. I picked up a MF10 with the mower deck at a farm auction last fall. Cleaned up the carb and replaced the fuel line and air filter and got it running pretty good. The one thing that is bugging me is the lift lever. I have no button screwed onto the inner shaft, just a pair of vice grips and a nut. I have looked at the parts page from AGCO, but can not picture how the spring and button go together. What holds the button on? Does the grip need to come off the outer sleeve to hold it on?
I'm just a little lost here.....
Thanks,
Mike
Also if anyone knows where to find a replacement button, spring, etc.... that would be amazing
#2 KennyP OFFLINE
  • 51030 Thanks
  • 52656 posts
Posted January 05, 2013 - 05:12 AM
Welcome to the forum! I can't help with the button issue, But one of the Massey folk will be around before long.
#3 mjodrey OFFLINE
  • 2374 Thanks
  • 13481 posts
Posted January 05, 2013 - 05:36 AM
Mike,welcome to the forum.Glad to have you with us.
Sorry ,I can't help you with your question.
#4 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted January 05, 2013 - 05:52 AM
First, :welcometogttalk: 77cjIN, good to have another Massey Guy on board.
Second, the rod is fine threaded, and the button is a nut. The spring sits on a shelf in the tube, and pushes back up on the button. The spring is about 1.25 inches long by 5/16. Those are approximate measurements from memory 2 years ago. My button was there, so I just bought a variety spring pack at TSC and played with a couple until I was happy.
The button goes down into the tube about a quarter inch when in the up position.
If you need to work on the rod ( clean up the threads, etc ), you can slide the rod down thru the tube if the tractor is about 8" off the floor and the lever is forward. Just don't bend it, if 8" isn't enough to clear the floor, carefully go higher.
If you need an example of what the button looks like, check out the one on the variator handle.
Good luck and let us know if you need more info. Oh, and we,d love to see pics of your Massey when you get a chance.
  • IamSherwood and HowardsMF155 have said thanks
#5 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 05, 2013 - 07:38 AM
Hi Mike.
Welcome to GTT. :wave:
If you're not in a rush, I can get you one of those buttons.
"The button goes down into the tube about a quarter inch when in the up position."
 How long would you say that button is?
Thanks for that info Alan.
#6 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted January 05, 2013 - 07:43 AM
I would have to go pull one to be sure, but around an inch. Depressed, The button is flush with the tube top and the rod clears the notches below by about 1/8" or so. To get the right hgt, the threads bottom out, so if someone makes one, they will have to think it thru.
#7 HowardsMF155 OFFLINE
  • 3079 Thanks
  • 3084 posts
Posted January 05, 2013 - 07:54 AM
Alan, thanks for that info, I've got a lift lever I need to repair myself.  So the button just twists on and off like a regular nut?
Welcome to GTTalk Mike!
#8 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted January 05, 2013 - 08:03 AM
Yes, but the rod is pretty thin, so dont just lock on a set of vise grips and twist. Not to say the rod is fragile, but some caution is a good idea. Bad thing is, without inverting the tractor, you cant get penetrating oil in there very well. I was afraid to heat as The rubber grip is there.
later, I found out you can remove the grip by warming it good with a hairdryer and pulling it off. Just dont scorch that 40 yr old rubber.
#9 Arti OFFLINE
Arti
  • 1493 Thanks
  • 1058 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted January 05, 2013 - 09:04 AM
Just stopped by to say Welcome to GTtalk
#10 KC9KAS OFFLINE
KC9KAS
  • 5535 Thanks
  • 4770 posts
Posted January 05, 2013 - 02:10 PM
Another Hoosier!  :welcometogttalk:  and if you have looked around here, you know... :wewantpics:
#11 77cjIN OFFLINE
77cjIN
  • 3 Thanks
  • 2 posts
Posted January 10, 2013 - 12:47 PM
Hi Mike.
Sherwood, I would greatly appreciate a button whenever you get a chance, its still frozen here so no rush. Let me know and I can paypal ya. I went out to start her up to get some outside pics, but battery is dead so all I have are garage pics.... first time uploading so I hope they show up. Complete with redneck vise grip modfication!
  • MH81, HowardsMF155 and MYAMF1010 have said thanks
#12 MYAMF1010 OFFLINE
MYAMF1010
  • 12 Thanks
  • 17 posts
Posted January 10, 2013 - 04:27 PM
:welcome:  to gttalk... thats a good looking tractor you got there. i like redneck lift arm botton.
~Calvin
