Kubota Head Torque Sequence ?
7 replies to this topic
#1 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 04, 2013 - 04:32 PM
 My head gasket is leaking oil when first started and so I am in the process of re-torqueing the booger ,as the bolts are not as tight as they are supposed to be {32 ftlbs) But I cant find the order in which to tighten them ? Anyone have this info ? Its a D 600.
#2 chris m ONLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted January 04, 2013 - 04:54 PM
Kieth we have a manual, if this is the same one the sequence is on page 149 http://gardentractor...-d640-b-v800-b/
  • skyrydr2 said thank you
#3 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 05, 2013 - 07:58 AM
That's the ticket !!! Thanks Chris and all for these manuals that one is awesome.
Looks like I will need to pull the head at some point and replace the gasket . The head bolts were up to factory torque specs.
It is easy enough to pull the head , its getting the parts that worries me????
I went to the local Kubota dealer last weekend looking for an oil filter.... Dahhhh what's a d600? What tractor is it in..... I say Walker, and he has no clue , and hands me a card with a 1800 # to contact Kubota....... Yeah OK... well your done ....
Any and all good dealers in this area are long gone ..... what a shame ... I'll have to find part numbers and get them from the INTERNET.
Support you local dealer.... yes I would... if he served rum at the parts counter....
Edited by skyrydr2, January 05, 2013 - 08:00 AM.
#4 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 21, 2013 - 04:27 AM
Well head gasket was replaced, not bad for it either, $23 . Job was easy Peasy!! And went quite well except for the restart after all was said and done...... that little booger gave me the worst time! And I really don't know why? I had the same issue when I was first trying to fire it up after install years ago ??? Just don't run it out of fuel I guess ?
Well anyways, as suspected..... the head had been changed.... and they forgot to install the o-ring at the oil restrictor for the valve train. This was the leaks cause, kind of a silly design if you ask me, why they didn't make the gasket with a sealing ring at this point is a wonder? But it was easy to fix , and if they had read the service manual..... they would have seen it.
At least I know its all good inside :)
  • KennyP and twostep have said thanks
#5 KennyP ONLINE
  • 40,934 Thanks
  • 47,125 posts
Posted January 21, 2013 - 06:30 AM
Glad  you got it all fixed up, Keith. Bet they were wondering what that o-ring was for!
#6 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 21, 2013 - 09:44 AM
Sad thing is it doesn't come with the head gasket.....
#7 KennyP ONLINE
  • 40,934 Thanks
  • 47,125 posts
Posted January 21, 2013 - 09:54 AM
That's rather dumb! You would think it would! But I'm glad it was a simple fix for the leak. So it takes a bit to get the fuel flowing right once you open the system?  It's been many years since I had a diesel around.
#8 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted January 21, 2013 - 11:30 AM
It does for this one ?? The worst one I have ever delt with.
