Bolens 850 W/ Attachments $800 Mass
This topic has been archived. This means that you cannot reply to this topic.
3 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,835 Thanks
  • 2,330 posts
Posted January 04, 2013 - 01:34 PM
http://southcoast.cr...3519016332.html
#2 OldBuzzard ONLINE
OldBuzzard
  • 6,987 Thanks
  • 4,784 posts
Posted January 04, 2013 - 06:40 PM
...This model has an on the fly locking differential. ...
Really?  That implies that you can engage it when you are moving.
I don't think I would want to try tightening up the diff lock that's in the center of the left wheel when a Bolens tube frame is moving.  :loosing_it:
Looks to be quite a bit over priced as well.
Edited by OldBuzzard, January 04, 2013 - 06:41 PM.
#3 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted January 04, 2013 - 09:09 PM
 That could be a very frightening experience LOL. If I went to look at it,the first thing I would ask is could you demonstrate the capabilities of the "engage on the fly diff"?
Edited by LTD, January 04, 2013 - 09:13 PM.
#4 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted January 05, 2013 - 09:37 AM
Actually, there is no problem to engage the locking diffrential while the tractor is moving.  ...It is easily done by reaching down and holding the red knob.  ....The turning axle (assuming trans is in a forward gear) will tighten the locking knob.
However, keep in mind that the differential lock is not normally used unless one wheel is spinning, in which case forward movement is usually stalled.
Locking the differential is acceptable whenever increased straight-line traction is needed, but the differential should be "unlocked" before turning.
