2166079sm Double Ended Ball Joint
hb112 landlord ssovereign baron
5 replies to this topic
  • 2,348 Thanks
  • 1,502 posts
Posted January 03, 2013 - 11:47 AM
I am trying to get my HB112 operational again.  I've repaired the leaks at the control pintles and have the Vickers T66X reinstalled.  While I was bleeding the system, I noticed there is a lot of slop in the control system: a large movement of the handle is required before the control pintle begins to move.  I traced it to the double ended ball joint (5/16"), which of course is NLA.  Has anyone fought this battle & found a working solution?
This item was also used on the Landlord, Baron & Sovereign series tractors.
loose ball joint.jpg control rod assembly.jpg alternate use location.jpg loose ball joint 2.jpg loose ball joint 3.jpg
Edited by New.Canadian.DB.Owner, January 03, 2013 - 11:50 AM.
#2 jms180 OFFLINE
jms180
  • 1,750 Thanks
  • 1,673 posts
Posted January 03, 2013 - 12:08 PM
i am not much help maybe one of the site sponsors can help you.
Edited by jms180, January 03, 2013 - 12:09 PM.
#3 boyscout862 ONLINE
  • 13,545 Thanks
  • 9,426 posts
Posted January 03, 2013 - 05:57 PM
I'd make the thing out of two generic balljoints with female ends and a piece of threaded rod. I'll look for a supplier. Try this : http://baileynet.com...ategory=1000055
Edited by boyscout862, January 03, 2013 - 05:59 PM.
  • Alc and New.Canadian.DB.Owner have said thanks
#4 glgrumpy ONLINE
  • 8,803 Thanks
  • 8,011 posts
Posted January 03, 2013 - 07:25 PM
Joining two was my idea also. Would become a little wider tho and might have to cut some stock off to bring tighter?  Maybe a tack weld would work if done quick?  That was some inventors dream for sure,ha!
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted January 03, 2013 - 07:32 PM
I don't know if you can find a replacement or not, I've never seen one like that anywhere I've looked. Take two regular ball joints, cut them down to the size you need and weld together. First cut the cut the rubber/plastic dust cover off, you will lose it anyway while welding. After parts are together, use a zip tie to secure the dust boot. Should last along time. :thumbs:
#6 KC9KAS OFFLINE
KC9KAS
  • 5,461 Thanks
  • 4,721 posts
Posted January 03, 2013 - 07:52 PM
That was my thought....Go to McMaster Carr website and look at tie-rod ends. Get 2 that fit your need, cut them shorter to fit your GT, weld and be happy!
Also tagged with one or more of these keywords: hb112, landlord, ssovereign, baron
