Steering Wheel Removal
jd314
23 replies to this topic
#16 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 04, 2013 - 03:29 PM
Larry if you won't be using it all that often, why not check with one of auto part stores on there loaning program, I don't know of ones in this area that does that but like they used to say 'let you fingers do the walking'.
Dick
  • larryd said thank you
#17 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 05, 2013 - 12:09 AM
Dick none of the parts stores carry a bearing seperator for rent or sale. Harbor Freight didn;t have one in stock either. Sold out.
I even tried 3 different pawn shops
Who da figured it be that hard to find one.
A   bearing seperator looks like 2 steelplateshalves that bolt together like a wedge under a bearing or gear and ypur puller fastens to it with bolts or jaws.
larryd
Edited by larryd, January 05, 2013 - 12:16 AM.
  • JRJ said thank you
#18 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 05, 2013 - 09:44 AM
I would think you could at least find something that would work and wouldn't cost you and arm & a leg. Did you try the Auto Zone in Centerton (spelling), I have been dealing with them lately and they seem to be pretty helpful, just another shot. What about TSC.
Dick
Edited by JRJ, January 05, 2013 - 09:45 AM.
#19 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 06, 2013 - 11:38 AM
JRJ , I t seems that most of the parts houses carrie the same items for loan or sale. But I will call them anyhow.
larryd
#20 UncleWillie ONLINE
  • 15,660 Thanks
  • 8,758 posts
Posted January 06, 2013 - 11:57 AM
larryd
You can order one from Harbor Freight online and have it shipped cheaper than running all over looking for one. I order stuff from HF all the time.
#21 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 06, 2013 - 10:00 PM
I got it off ! I read a post that ( poncho62 ) had posted about making his on puller,
.So I made a set  up of angle iron as he said , installed puller , clamped down tight , soakes it again with penetrant , ate dinner , came back and gave puller a 1/2 turn walked to bench too get my drink and I heard it pop loose. HORRAY !
Now I can continue with my clean up so I can paint.
Thanks to every one for their suggestions and help .
larryd
  • KennyP and JRJ have said thanks
#22 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,998 posts
Posted January 06, 2013 - 10:03 PM
larryd
:rolling: :dancingbanana: :rocker:
  • UncleWillie and larryd have said thanks
#23 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 07, 2013 - 09:57 AM
Glad to hear you finally got it off, just don't forget to put a very small amount of anti-seize on the shaft and on the inside of the SW when replacing it. If you haven't every used it before, it can be very messing and a little bit goes a long ways.
Isn't it a little cool- I mean cold to be painting.
Dick
#24 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 07, 2013 - 05:27 PM
Dick , Yes a little , but I have heat in my garage. I will use anti-sieze . I use it regularly
laryd
Also tagged with one or more of these keywords: jd314
