Steering Wheel Removal
jd314
23 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 02, 2013 - 11:47 PM
What type of puller do you use to pull a real real Stubborn wheel. The man I bought mower from just put this new steering wheel on about 6 months ago. I am trying to remove it so I can remove the dash tower for tractor repaint
larryd
#2 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 03, 2013 - 01:11 AM
Have you tried doing a search here. This topic has been debated many times, and there are
all sorts of different an good ideas. Perhaps you'll find one that'll work for you.  How you
do it, depends alot on wheel type, column size, and space available between wheel and
column. Maybe post a picture.
Good luck.
  • larryd said thank you
#3 mjodrey OFFLINE
Posted January 03, 2013 - 05:01 AM
I have always used a bearing separator.
#4 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 03, 2013 - 05:02 AM
I've always used a flywheel seperator.  Seems to have worked everytime.  I agree however it does  have alot to do with the type and size of the wheel.  You may just be fighting yourself.
#5 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted January 03, 2013 - 05:38 AM
I'm with Maynard on this, bearing seperator/ tee bar puller combo will remove it easily.
http://www.harborfre...-set-93980.html
Edited by skyrydr2, January 03, 2013 - 05:41 AM.
#6 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted January 03, 2013 - 06:49 AM
Larry, if this is on the 314 you need to watch out that you don't damage the hollow shaft on the steering gear. Don't pound on the shaft. It can break the alluminum casing of the gear. You need some sort of puller, penetrating oil and time. Try to keep it soaked in penetrent for at least several days. One thing I've done is heat up the wheel hub, gently, with a heat gun, being careful not to damage it. I do this a few times while letting it cool in between and keeping the oil on it between heat sessions. The thermal cycles help to break the bond. If this wheel has only been installed for 6 months it should come right off unless the spline was damaged.
  • boyscout862 and larryd have said thanks
#7 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 03, 2013 - 10:57 AM
Larry if that steering wheels has only been on for a short period of time it shouldn't be all that hard to remove. Get the inside stuff out of the way if you haven't done so already. Apply you choice of fluids to break it loose and let them work for awhle, break the nut loose and then sit on the seat with the wheel resting on your knees, with the nut about half off take a piece of wood and place on top of the nut and then with a hammer of choice and strike the wood while appling pressure to the under side of the wheel, then it should pop off.
Then when you go to replace it don't forget to place never seiz either on the shaft or on the inside of the steering wheel.
Dick
Edited by JRJ, January 05, 2013 - 09:35 AM.
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted January 03, 2013 - 12:47 PM
JRJ beat me to my recommendation.  The way he suggested is the way I usually do it as well.
#9 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 03, 2013 - 05:17 PM
Before I made my suggestion I had to go to the JD parts and take a look at it for there were or is a few JD's that are secured it a different fashion and I don't remember which models it is and how they are removed, and I didn't want to inform Larry the wrong way.
Dick
#10 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 03, 2013 - 06:04 PM
I used my two jaw puller.Dropped a bolt to fit in the hollow shaft and gradually increased pressure while tapping on puller bolt 'til she popped loose. Used plenty of antiseize on reass'y. Deformed the plastic on the bottom of the wheel hub a little but I'm not in restoration mode anyway.
Mike
#11 UncleWillie OFFLINE
  • 15,666 Thanks
  • 8,761 posts
Posted January 03, 2013 - 06:27 PM
Step one: Put your wife on the tractor.
Step two: Make her really really mad.
Disclaimer: This poster nor the staff, management, or members of GTT are responsible for physical harm, property damage, tractor destruction, divorce or alimony payments that may result from following this advice.
  • Texas Deere and Horse, IamSherwood, KennyP and 2 others have said thanks
#12 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 03, 2013 - 11:27 PM
Thanks to everyone. I think I am just going to go buy me a bearing seperator.
larryd
  • JRJ said thank you
#13 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 04, 2013 - 11:52 AM
Larry I really don't think you should need it-but you are the boss.
Dick
Edited by JRJ, January 05, 2013 - 09:39 AM.
#14 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 04, 2013 - 12:21 PM
Larry is the bearing seperator the tool that looks like a heavy duty tuning fork.
Dick
Edited by JRJ, January 05, 2013 - 09:40 AM.
#15 skyrydr2 OFFLINE
  • 3,886 Thanks
  • 3,410 posts
Posted January 04, 2013 - 02:04 PM
Larry is the baring seperator the tool that looks like a havy duty tuning york.
Dick
see post #5 above there is a link to one .
Also tagged with one or more of these keywords: jd314
