Db Snow Blade Question
5 replies to this topic
#1 Alc OFFLINE
  • 7,127 Thanks
  • 7,530 posts
Posted January 02, 2013 - 09:42 PM
I'm not sure if this is the correct blade for my 600 or maybe the hitch is bent ?  The problem is it's hard to pull the pin back to let the blade pivot , any ideas ?  Al
#2 Alc OFFLINE
  • 7,127 Thanks
  • 7,530 posts
Posted January 03, 2013 - 06:34 AM
I guess should have said that it doesn't seem like enough room for the pin to be able to be pulled before it hits the hitch . Al
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted January 03, 2013 - 07:10 AM
I think the hitch needs to come off, the parts breakdown shows a brace from the bottom of the blade to the front of the transmission.
#4 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 03, 2013 - 11:56 AM
yep, thats the trouble, the hitch needs to off and you have to run the brace , or you will bend the blade. This is one of  the poorer DB designs. I hate when i have take parts off to make stuff work right.
#5 Alc OFFLINE
  • 7,127 Thanks
  • 7,530 posts
Posted January 08, 2013 - 08:43 AM
Thanks guys , the fellow I got the tractor from said his uncle got the blade at an auction and never had it on , I got the brace from Casey and I attached it to the hitch . Maybe I don't have the correct brace for this tractor ? I'll have to see if it mounts once I remove the hitch , Al
#6 Alc OFFLINE
  • 7,127 Thanks
  • 7,530 posts
Posted January 08, 2013 - 08:11 PM
I was going to take the hitch off tonight but first had to remove the brace   , it was one of those nights that everything fought me lol . The little notch to hold the kickstand down is so worn it kept going over the notch and wouldn't hold the tractor up :wallbanging:  Anyway once I had the blade off the ground I realized the pull pin was almost all the way back and you couldn't even wiggle the blade , the brace was jammed so tight it was couldn't even get the hitch pin off . Noticed that it wasn't the pin keeping the blade from moving but the curved part jammed into the bracket :wallbanging:  I'm going to try making a longer brace , that should give me more clearance while turning the blade . Al
