Mf16/18 Just Acquired
19 replies to this topic
#1 jimed5353 OFFLINE
jimed5353
  • 4 Thanks
  • 9 posts
Posted January 02, 2013 - 08:21 PM
recently acquired a mf/snapper 16/18 series tractor....not sure of actual branding or year or make due to no serial plates..
after getting it home I have noticed a few issues I could use some help with
1. motor has been replaced with Briggs 16 hp
2.  Runs reverse when depressing forwards and vice versa
3.  Runs faster in reverse than forward.
4.  do the onan and briggs motors rotate a different direction than each other?
Thanks for all help and advice in advance..
#2 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted January 02, 2013 - 08:24 PM
:welcome: to GTTalk!
It almost sounds like the Original engine and the replacement engine were orientated the other way around.
If you happen to have a picture or three, it might help the more knowledgeable guys help you.
#3 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1233 Thanks
  • 1461 posts
Posted January 02, 2013 - 08:34 PM
:welcometogttalk:  :wewantpics: welcome and glad to have another tractor nut around..lol.  We all love pics so post some up and it always makes life easier helping out with a problem if we have a visual.
#4 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted January 02, 2013 - 09:01 PM
Sounds like the motor rotation is backward. Dony worry, this can be fixed. This tractor wasnt the one on Craigslist over near Denton was it?
#5 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted January 02, 2013 - 09:02 PM
Hello Jim
Welcome to GTTalk!  Great to have another fellow from NC here!  By chance did you get this machine with two others from somewhere around Greensboro?
I don't know enough about this series to help, but there are a bunch of knowledgeable guys here that should be able to help.
#6 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 02, 2013 - 09:24 PM
Hi, and welcome to GTT.
Are you saying you have either a MF1655, or MF1855?
If so, sorry I can't help you out engine wise, as I've only got the 1450 and1650. They have Kohlers.
It would help others that know, if you could post some pics of the engine etc.
#7 jimed5353 OFFLINE
jimed5353
  • 4 Thanks
  • 9 posts
Posted January 03, 2013 - 09:36 AM
I will post up close up pictures when I get home either today or tomorrow
yes it is the one that was on CL near Denton....got a better deal than posted and already sold the other two mowers I really only wanted the MF anyways
I was thinking the same thing about the motor rotation being an issue.  Im looking to rehome an 18-20 hp on it anyways..just not sure which one..but if the 16hp briggs on it can be utilized it would save me some money to spend on restoring..
Thanks and I will post up pics asap
#8 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted January 03, 2013 - 02:14 PM
Welcome to the forum.Glad to have you with us.
Looking forward to some photos.
#9 jimed5353 OFFLINE
jimed5353
  • 4 Thanks
  • 9 posts
Posted January 04, 2013 - 07:39 PM
A few pics of the new project
#10 jimed5353 OFFLINE
jimed5353
  • 4 Thanks
  • 9 posts
Posted January 04, 2013 - 07:47 PM
The rest of the pics...
Seems to have a few modified/non factory reconfigurations..looking to put it back to original
the rear pto is out and I don't have the connector sleeve
the mower deck is out and no short shaft or front pulleys
Somebody liked john deere green and painted to items..
harness is butchered and key no longer works so it has a switch and push button start
trans cooler and lines were added   I want to do away with that
and as stated in previous post   forward is reverse and reverse is forward...looking at the motor it appears to have been installed backwards to make the shafts work.......can I turn it around and find adaptors, etc.... to make it run correctly
thanks everyone
#11 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted January 04, 2013 - 08:14 PM
The engine is oriented correct, as the hydro is to be driven off the flywheel side.  Not sure what's up with the backwards controls, so someone must have monkeyed around with the control linkages.
#12 HowardsMF155 OFFLINE
  • 3107 Thanks
  • 3091 posts
Posted January 04, 2013 - 08:16 PM
Looks like you're making some small progress, finding out what is what.  I thought the trans cooler looked aftermarket.  It's a shame the thing is running backwards.
I'm a bit surprised that the motor runs backward, I thought all motors ran the same direction.  I wonder if the motor is installed backwards from what the original was.
#13 olcowhand OFFLINE
  • 44107 Thanks
  • 32302 posts
Posted January 04, 2013 - 08:19 PM
The engine is hooked up right. HAS to be something with the linkages I'd say.  A close-up pic of all the linkages at the hydro unit will tell the tale most likely.
#14 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted January 04, 2013 - 08:46 PM
I don't know, but isn't the face plate of the hydro reversible? As in rotating it 180* ?
#15 coldone OFFLINE
coldone
  • 1716 Thanks
  • 1709 posts
Posted January 04, 2013 - 10:19 PM
I am glad  you got it but I sure hate I missed it. I have been wanting the Massey version, i have two of the snapper versions. The splined couplers can sometimes be found at surpluscenter.com. That can get your rear PTO going. You got some great goodies with that purchase and these things are a beast. I am thinking that the charge pump on the hydro got reversed. There is a  manual for the sundstrand 15 series hydro here in the manual section.  I think my 1855 engines turns CW looking at the flywheel end.
Great score, glad you got it and found your way here to GTtalk.
