Filling Transmision Sears Ss16
1975 sears ss16 onan engine
14 replies to this topic
#1 BigC OFFLINE
BigC
  • 1 Thanks
  • 2 posts
Posted January 01, 2013 - 06:38 PM
Transmission has a pipe tread el behind one of the rear wheels I don't see and overflow plug to see when the transmission is full. The insructions say to put 5 qt sae 30w oil. There is nowhere to release air trapped in the transmission so the bebbles come out the same hole you are pouring oil and you end up with more oil on the ground than in the tranmission. Tractor is 1975 SS 16 with high low 3 speed transmission. Also where does the wire from the Staring switch marked "I" connect. The scematics show it going to the coil,but it is only 16" long and has a round bolt terminal. Any help would be appreciated. BigC.
#2 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted January 01, 2013 - 06:58 PM
Welcome to GTT. I don't have answers to your questions but someone to help will be along in a little while. Check out the manuals you can download. Good Luck
  • BigC said thank you
#3 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted January 01, 2013 - 07:03 PM
Welcome to GTtalk BigC. I haven't owned a sears yet so I don't know.
Being a Holiday A lot of our resident Sears experts maybe out and about today. But I am sure they can point you in the right direction.
Good Luck!
#4 stripmine OFFLINE
stripmine
  • 36 Thanks
  • 29 posts
Posted January 01, 2013 - 07:04 PM
There is a pressure release valve ( vent) on the right side of the trans-axle,  toward the rear, near where the Hi / low selector shaft comes out. they often get plugged up. I'm fairly sure that they screw out, and could be cleaned with some disc brake cleaner.
When I have trouble getting fluid in, i use a piece of aquarium air tubing shoved thru the funnel and into the fill opening  to act as a vent. just make sure that the end of the tubing   is above the level of the funnel so that it doesn't get oil in it.
As for the wire from the I terminal, yes.. it goes to the coil.
  • MH81, Arti, BigC and 1 other said thanks
#5 olcowhand ONLINE
  • 42,897 Thanks
  • 31,941 posts
Posted January 01, 2013 - 07:06 PM
I would use a marine oil pump that fits onto quart bottles.  The hose will slip through the fitting all the way into the trans case, so the bubbles won't fight you.  Walmart has them, as well as marine supply stores & more.  I have the same problem filling some of my hydro diffs, and this pump was a super fix.
  • MH81, stripmine, Arti and 1 other said thanks
#6 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted January 01, 2013 - 08:04 PM
  :welcometogttalk: Welcome BigC, how about a few pictures of that Sears?
#7 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted January 02, 2013 - 04:55 AM
:welcometogttalk:  :wewantpics: , yes the directions are correct. It does take SAE 30 and 5 qts of it.  Don't get fancy, alota people will tell you to alter the type or amounts of fluid. Stick to the manual.  That wire does in fact go to the coil.  If you need help on any of this such as a visual, just ask, many of us can post pics of our own stuff or email them to you as referance.  I have also, along with others, posted manuals and diagrams of all sorts of things so in the manual section you may find what you need as well.  One more option is always youtube.  Believe it or not there is alota helpful info there and great visuals.  Glad to have another tractor fan with us so have fun and look around its a great forum......POST PICS.......
#8 mjodrey OFFLINE
Posted January 02, 2013 - 05:40 AM
BigC,welcome to the forum.Glad to have you with us.
#9 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 02, 2013 - 05:54 PM
BigC;  Welcome to GTtalk, as you have already found there are many helpful member here.
 On filling that transmission, don't get into a hurry-it will alll go in as advised, just make sure you have drain ALL of the old stuff out.
Also it is suggested pictures help a WHOLE lot.
Dick
Edited by JRJ, January 02, 2013 - 05:55 PM.
#10 BigC OFFLINE
BigC
  • 1 Thanks
  • 2 posts
Posted January 17, 2013 - 09:46 PM
Pictures of my SS 16. Have rear of tractor and the engine and sheet metal for the front painted. I only get to work on it  an hour or two a day and work in a partially heated garage. The warm spell last week helped. Will let paint dry til Monday and start again. Only leaves the hood to paint. While looking at the manual it showed a washer under the left rear motor mount. Anyone know why.
#11 KennyP ONLINE
  • 40,899 Thanks
  • 47,099 posts
Posted January 18, 2013 - 05:57 AM
Welcome, BigC! That looks very nice!
#12 TAHOE OFFLINE
TAHOE
  • 8,307 Thanks
  • 5,803 posts
Posted January 18, 2013 - 10:27 AM
Welcome to GTT fellow Ohioan.
Yes, filling those trannies are a royal pain in the rear. Took me about 45 mins to fill mine, I even heated the oil in a water bath on stove to make it thinner. I just sat there pouring a small stream in letting it conitnually burp. what a pain. The factory oil lasted 35 yrs so I doubt I will ever have to do it again.
#13 1oldbuzz OFFLINE
1oldbuzz
  • 606 Thanks
  • 487 posts
Posted March 01, 2015 - 05:23 AM
Easiest tranny fill I have done.
put shifter in neutral
remove the shifter.
4 bolts a little tricky with the safety switch
plate.
Remove the regular fill plug so it vents.
Set your funnel in the shifter hole and pour away.
You need a little patience getting the shifter and bolts back in
small hands help  alot here
Don't forget to put the fill plug back in
And if all old oil is drained completely
It will take the 5 quarts
Hope this helps
#14 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 308 Thanks
  • 241 posts
Posted March 01, 2015 - 09:10 PM
remove the shifter.
plate.
Hope this helps
he hit it right on head i take all my shifters out to fill the trannies
#15 dannyboysd OFFLINE
dannyboysd
  • 1 Thanks
  • 6 posts
Posted April 02, 2016 - 07:52 PM
Thanks 1oldbuzz, made the filling pretty easy, now to put it all back together again.
