Starting On The Jd 68
rer
33 replies to this topic
#1 grnspot110 ONLINE
grnspot110
  • 4,145 Thanks
  • 2,640 posts
Posted January 01, 2013 - 12:12 PM
Time to start work on the 68!  I picked this up at a plow day in October, mentioned to a "tractor friend" there, that I planned to go to an auction the next weekend to try to get a 56 RER for a project I had in mind.  He said he could do better, FREE!  He called somebody & made arrangements to pick up one at his local dealer after hours that afternoon.  When we got there, this 68 was setting out back ready to be loaded.
Mower is in overall good condition, though the seat was shot, tires bad & steering wheel broken.  I brought it in the shop a couple months ago, but hadn't done much to it yet.  I had the carburetor rebuilt & acquired a used starter for it!  It now starts & runs, all gears work, just needs loosening up, cleaned & painted!  Also took the steering wheel off, epoxied the two broken spokes & run long screws through the bottom of the spokes into the hub.
This morning, I used Bondo to finish filling the cracks & will paint it with semi-gloss black. Will start sanding the engine housing this afternoon.  Waiting on a new ignition switch before pulling the engine.
Due to the condition, I've decided to restore it as close to original as possible.  Will be used for shows & as a backup mower.
BTW, I got the 56 too, it will probably be my next project!  ~~  Lowell
  • Texas Deere and Horse, KennyP, sacsr and 2 others have said thanks
#2 mjodrey OFFLINE
Posted January 01, 2013 - 12:30 PM
Should look nice when you get it restored.
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,769 Thanks
  • 4,261 posts
Posted January 01, 2013 - 12:42 PM
Hi Lowell, please don't forget posting pics after restoration! Very nice, interesting riding mower!
#4 KennyP ONLINE
  • 38,173 Thanks
  • 45,836 posts
Posted January 01, 2013 - 07:21 PM
Great! I have one of those! And it was a freebie also. Cool little mower!
#5 grnspot110 ONLINE
grnspot110
  • 4,145 Thanks
  • 2,640 posts
Posted January 05, 2013 - 12:54 PM
So far, I've just been tinkering with it; painting the engine tins, housing & air flow tins.  Well, today I decided to tear into it:
Took several pics from underneath so (hopefully) I can put it back together, ​no guarantees!:
Lowell
  • Texas Deere and Horse and KennyP have said thanks
#6 KennyP ONLINE
  • 38,173 Thanks
  • 45,836 posts
Posted January 05, 2013 - 03:04 PM
I had to replace the drive belt on mine. Took a bit to get everything back as it should be. These have a weird set up. But I finally got it to work again.
#7 grnspot110 ONLINE
grnspot110
  • 4,145 Thanks
  • 2,640 posts
Posted January 05, 2013 - 05:00 PM
Did you have to take the pulley off the transmission?  Looks pretty tight under there!
~~  Lowell
#8 KennyP ONLINE
  • 38,173 Thanks
  • 45,836 posts
Posted January 05, 2013 - 05:56 PM
No, but that may have been easier! And yes, it's dang tight.
#9 grnspot110 ONLINE
grnspot110
  • 4,145 Thanks
  • 2,640 posts
Posted January 06, 2013 - 07:36 PM
Got it stripped down as far as I'm going to today:
Cleaned & painted a few parts, will be later this week before I get much else done with it!  ~~  Lowell
#10 Trav1s ONLINE
Trav1s
  • 3,283 Thanks
  • 4,347 posts
Posted January 06, 2013 - 07:39 PM
Looking good Lowell!
  • grnspot110 said thank you
#11 grnspot110 ONLINE
grnspot110
  • 4,145 Thanks
  • 2,640 posts
Posted January 12, 2013 - 12:38 PM
Been busy cleaning & painting the small parts, including the rims:
Next comes cleaning & painting the frame!  ~~  Lowell
#12 Texas Deere and Horse OFFLINE
  • 14,792 Thanks
  • 15,492 posts
Posted January 12, 2013 - 12:44 PM
Looking good Lowell, Free is always good. Can't wait to see it finished.
#13 grnspot110 ONLINE
grnspot110
  • 4,145 Thanks
  • 2,640 posts
Posted January 17, 2013 - 05:15 PM
Frame is painted with some parts put back on:
"shroud" & "console" are primed:
Hope to paint the green tomorrow, then start putting it back together next week.  Next will be getting the 30" deck operational and cleaned & painted!  ~~  Lowell
#14 KennyP ONLINE
  • 38,173 Thanks
  • 45,836 posts
Posted January 17, 2013 - 05:27 PM
Good to see progress, Lowell! I'll have to get mine out and play with it again this Spring!
#15 grnspot110 ONLINE
grnspot110
  • 4,145 Thanks
  • 2,640 posts
Posted January 18, 2013 - 05:41 PM
Painted the console & shroud today!  Masked off the decals since they were in good shape & NLA from "mother Deere".  Had the console decal made by: http://www.clickitan...cal-click-here/
Primed with Rustoleum "light grey automotive primer" (spray cans):
Final sanding with 3M "waffle pads" (400 grit):
Painted today with JD "Ag Green", my $50 HVLP gun I bought at Sutherland's 4-5 years ago:
My compressor is in another shed 60' from the shop, so I string a hose across to a pipe through the shop wall, then hook up the small regulator/moisture trap inside the shop:
Finished paint job:
Lowell
  • KennyP and sacsr have said thanks
Also tagged with one or more of these keywords: rer
