Homemade Snow Plow
homemade snow plow white / jacobsen gt
96 replies to this topic
#1 Watchdog OFFLINE
Watchdog
  • 132 Thanks
  • 113 posts
Posted January 01, 2013 - 09:00 AM
Good Morning Everyone:
Yesterday I got started building my homemade snow plow for my White Town & Country 112.  I was given the GT without any implements or even a mower deck, so I decided I needed to do something with it.  Not to mention it"s been snowing a lot and plowing looks like fun.
So this is my basic salvaged materials, along with bit of junk I have tucked away in the corners of my shop.
This is the blade material.  I plan to cut it in half and laminate the two halves together.
These are some scrap from work.  They used to join together to support radiant heaters, which are used to defrost the ground.  Originally they extended but the innner 1 1/4" tube is rusted in place.  So I have 1.5 inch by 1/4 wall tubing for my push frame.
This my push frame mount ( x 2) made of 3" channel.  The 3/4 hole in the GT frame was already there so I robbed a couple 3/4 bolts from from a couple of old trailer hitch balls.
A pic of the mount welded to part of the push frame.
Both sides of the push frame with a centre support.
The front starting to come together.
A hook I made out of some galvanized rod, to act as the lift point on the deck lift mechanism.
The lift chain is passed through the frame support and wrapped around the whole frame in an effort to lift the push frame evenly. I'll probably work on the lift to come up with something better a little later.
Does anybody have a picture of how their plows lift?  Am I at least close to figuring out how they are supposed to lift?  I only get about four inches between the lifted and lowered positions.
More to follow soon.  Hoping to get the work done today and paint tomorrow.
Any input you can offer would be appreciated.
Thanks
Jeff
  • JDBrian, CRFarnsworth, boyscout862 and 2 others have said thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 01, 2013 - 09:12 AM
Interesting build. Thanks for the pictures Jeff. Keep us updated!
  • JRJ and Watchdog have said thanks
#3 poncho62 OFFLINE
poncho62
  • 2,123 Thanks
  • 1,790 posts
Looks good so far....A lot of the plows have framework with an up/down bend in it, like the bar on the left of this picture. That allows the blade to lift higher.
$(KGrHqF,!rkFC(RDN0rrBQuuwjN9bw~~48_20.J
#4 KennyP OFFLINE
  • 40,949 Thanks
  • 47,132 posts
Posted January 01, 2013 - 09:19 AM
Looks like you're making progress. Watch cutting that tank, though. As far as the lift only being 4", that is a challenge when running the assembly under the front axle. Hard to get much lift that way.
  • Watchdog said thank you
#5 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted January 01, 2013 - 09:32 AM
CAN I COME PLAY IN YOUR SHOP? Please. I love a down to earth DIY build from scratch project thread. I'll be following. Thanks for the pics and description. Keep us posted. Oh, is that a GT lift your tractor is on that you just happen to have sitting around your shop? If so, that's really cool.
#6 mjodrey OFFLINE
Posted January 01, 2013 - 09:39 AM
Looks like you are off to a good start.
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 01, 2013 - 09:47 AM
I personally think 4" of lift is all you need. That's about all I have w/ the GT blade I adapted to fit my wheeler. It works well ramping up the snow as I have to due to space limitations. If you think you need more lift cut the push arms just ahead of the front axle w/ the sawzall or cutoff wheel on the top and sides. This would have to be done after the blade is built and mounted. Keep veeing out the cuts so the arms almost touch the floor, then tack them in place, remove from the GT and weld up good.
For the moldboard, when you say laminate, do mean back to back to make it stronger or end to end to lengthen it? If you have some more of the sq tube, make a strong back to span your welding table and use it w/ a bottle jack as a press to increase the radius of the moldboard.
These are only suggestions of things I would do.
Mike
#8 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted January 01, 2013 - 09:56 AM
Looking good!  You are making it very heavy duty, so it should last a long time.
  • JRJ, Watchdog and welderman85 have said thanks
#9 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted January 01, 2013 - 10:02 AM
Looks like you know what you are doing....Keep us posted on the progress!
#10 boyscout862 ONLINE
  • 13,556 Thanks
  • 9,431 posts
Posted January 01, 2013 - 10:23 AM
You're doing a very nice job. My Ford and Snapper tractors have plow frames that mount to the rear axle like you're doing. They both have a center guide mounted to the front of the tractor frame to keep the plow centered under the front axle. One has two angles pointing down that straddle the plow frame. The other tractor has a piece of channel welded to the plow frame that comes up in front of the grill and is straddled by two angles that go horizontally forward from the tractor frame.
Are you going to make the blade spring trip? I recommend it. I used a fixed blade for awhile but ended up on the hood of the tractor when hitting rocks. Thanks for the pictures and good luck.
Edited by boyscout862, January 01, 2013 - 10:27 AM.
  • Moosetales, JRJ and Watchdog have said thanks
#11 Moosetales OFFLINE
Moosetales
  • 1,089 Thanks
  • 1,284 posts
Posted January 01, 2013 - 10:36 AM
LMAO! Just picturing boyscout all sprawled out on the hood of his GT makes me laugh. :bigrofl: Better wear a helmet and a seat belt if you don't make the blade "spring trip".
  • KennyP, boyscout862, JRJ and 1 other said thanks
#12 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted January 01, 2013 - 10:53 AM
Your progress looks really good!! A thought is to build a pivot into the push bar at the front area. Then mount the push bar in a solid manner. This will give you more lift options and more lift travel.  IMHO
Geno
#13 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,807 Thanks
  • 4,302 posts
Posted January 01, 2013 - 11:03 AM
good work!
#14 boyscout862 ONLINE
  • 13,556 Thanks
  • 9,431 posts
Posted January 01, 2013 - 11:36 AM
To an observer it was funny. I chuckle now. Ed and Jim, my neighbors at the time, were laughing as hard as they could. So they got on the hood of my Raider 9 and we plowed the road together. That was over thirty years ago. I then got a spring trip plow(like most are) and didn't have trouble with the tractor until 5 years ago when the engine wore out. Twenty years ago I went over a big rock on my A/C HD6G and ended up on the hood of it. If I hadn't caught the throttle with my foot as I went over, it would have kept going. Boys playing with toys.
#15 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 01, 2013 - 11:54 AM
Good Morning Jeff and a Happy New Year;
 Now that looks like a man that is  on a mission and knows what he is doing. I like to see a young man with the spunk to made something out of just about nothing, give the man  a cutting torch, a welder and some metal and he can build what ever he wants.
 A very good job so far, my concern right now is, isn't it a little bit cool to be outside working like that, even in a garge can be uncomfortable.
Looks like you have the tiger by the tail now.
Dick
