Helix Roller
15 replies to this topic
#1 kwj427 OFFLINE
kwj427
  • 57 Thanks
  • 137 posts
Posted January 01, 2013 - 08:35 AM
hi,
does anyone here have one of these? it mounts on the tractor, and when lowered it raises the rear of the tractor off of the ground, contacting the rear tires. so forward is reverse, and reverse is forward. there is not a plug to fill the drum with anything? i guess it uses the tractor and driver as ballast?
thanks kenny
  • Alc, IamSherwood, JDBrian and 4 others have said thanks
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 01, 2013 - 08:51 AM
That's something I've never seen before. It would be interesting to see it in operation. You can see what looks like darker areas on each end of the roller where the tires would have contacted it. What tractors was it designed to fit?
  • kwj427, WNYTractorTinkerer and trackcar have said thanks
#3 mjodrey OFFLINE
Posted January 01, 2013 - 09:38 AM
Interesting,don't think I've seen one like that either.
#4 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted January 01, 2013 - 09:39 AM
Here's a pic of the roller in use.
  • kwj427 and IamSherwood have said thanks
#5 Littledeere OFFLINE
Littledeere
  • 1,658 Thanks
  • 1,487 posts
Posted January 01, 2013 - 09:42 AM
Does that one  have a Sears tag on it they are the only ones I have seen so far
Edited by Littledeere, January 01, 2013 - 09:43 AM.
#6 Moosetales OFFLINE
Moosetales
  • 1,089 Thanks
  • 1,284 posts
Posted January 01, 2013 - 09:43 AM
Here's what appears to be a source for info on this lawn roller:
Vintage Sears Garden Tractors
(scroll down the page till you get to "Lawn Roller")
http://vintagesearsg...ccessories.html
That is cool.
Edited by Moosetales, January 01, 2013 - 09:44 AM.
#7 Moosetales OFFLINE
Moosetales
  • 1,089 Thanks
  • 1,284 posts
Posted January 01, 2013 - 09:46 AM
This isn't the actual lawn roller listed above but it is a cool video of times gone by.
  • Alc, IamSherwood and KennyP have said thanks
#8 IamSherwood OFFLINE
  • 8,395 Thanks
Posted January 01, 2013 - 09:51 AM
That is so neat.
Certainly meant for straight line driving.
Thanks for posting this info.
#9 KC9KAS ONLINE
KC9KAS
  • 5,464 Thanks
  • 4,722 posts
Posted January 01, 2013 - 10:06 AM
Even grandma got in on the "Rolling Fun"......Thank goodness for long dresses! :worshippy1:
  • Moosetales said thank you
#10 kwj427 OFFLINE
kwj427
  • 57 Thanks
  • 137 posts
Posted January 01, 2013 - 10:56 AM
it fits 1963-67 john deere 110'2 and 112's. it has helix declas on it. i may try to put some pictures in my gallery, i tried to put more on the topic, but no luck.
#11 Utah Smitty OFFLINE
Utah Smitty
  • 1,709 Thanks
  • 1,792 posts
Posted January 01, 2013 - 10:57 AM
hi,
thanks kenny
So, what do you plan to do with it... lay down asphalt for your driveway?? :o}
Steve
#12 kwj427 OFFLINE
kwj427
  • 57 Thanks
  • 137 posts
Posted January 01, 2013 - 11:03 AM
i will might use it to level the yard?
Edited by kwj427, January 01, 2013 - 11:03 AM.
#13 kwj427 OFFLINE
kwj427
  • 57 Thanks
  • 137 posts
Posted January 01, 2013 - 11:05 AM
that is a cool video!
#14 Littledeere OFFLINE
Littledeere
  • 1,658 Thanks
  • 1,487 posts
Posted January 01, 2013 - 08:05 PM
That's a cool attachment you can come and roll my yard and just leave it here :smilewink:
#15 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted January 19, 2013 - 05:25 PM
That's a cool attachment you can come and roll my gravel driveway and just leave it here :smilewink:
Never saw one. Curious, wouldn't it work better if it could be water filled?
Guess the tractor and driver weight add to the down pressure.
Can steering still work? Drive slow?
Edited by Tankman, January 19, 2013 - 05:27 PM.
