J D 140x2 Restore Started.......
8 replies to this topic
#1 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,164 Thanks
  • 2,935 posts
Posted December 31, 2012 - 10:42 PM
I have both of the 140's in the garage, and I got started taking them apart to see what I have.  I took some pics of the H3.  Oh my, it is nasty.  Dirt-gunk caked on everything underneath.  I already scraped off over an inch thick of crap in some places when I took these pics.  I think what I will do is to pull the motor off this one (H3) and get the other one (H1) taken apart the same and then take them both to the carwash. [attachment=54104:100_8959.jpg][attachment=54107:100_8962.jpg][attachment=54109:100_8964.jpg]
There are a couple of holes in the fender of the tractor deck on the H3, other than that it is good shape.  The tractor deck on the H1 is cracked at the seat mount.[attachment=54106:100_8961.jpg]
One thing interesting to see is that the H3 has the plain cooling fan on it, not the one for a rear-pto.  And it does not look like it ever had anything bolted up to the back of the tractor either.[attachment=54108:100_8963.jpg]
The motor turns over, and I can see that the piston moves up and down.  I don't know anything else about it.  I sprayed some fogging oil in the spark plug hole and let it set for awhile before I tried turning the crank by hand.[attachment=54110:100_8965.jpg]
  • boyscout862 and larryd have said thanks
#2 KennyP ONLINE
  • 40,866 Thanks
  • 47,089 posts
Posted January 01, 2013 - 05:52 AM
Yuk! Lots to clean in there. Hope there are no surprises hidden away! Thanks for the pics of the 'innards'. Helps me understand how JD did things.
  • jimbobbillyray said thank you
#3 mjodrey OFFLINE
Posted January 01, 2013 - 06:04 AM
Looks like you have a little work ahead of you.
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 01, 2013 - 07:53 AM
The 140 in the first picture has the original style rear end by the looks of it. The frame is mostly identical to the 300 to 317 tractors except for motor mounts and other details.
  • jimbobbillyray and larryd have said thanks
#5 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,164 Thanks
  • 2,935 posts
Posted January 14, 2013 - 04:10 PM
Finally had some time and got the motor out of the H3 this last weekend.
[attachment=55650:100_8974.jpg][attachment=55651:100_8976.jpg][attachment=55652:100_8975.jpg]
If it ever warms up around here I will do some power washing and see what I got.
  • larryd said thank you
#6 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 14, 2013 - 07:38 PM
Looks like the motor cylinder is dry and clean. No head gasket leaks on that one. The consoles always rust due to the battery. That one doesn't look too bad.
#7 jimbobbillyray OFFLINE
jimbobbillyray
  • 3,164 Thanks
  • 2,935 posts
Posted January 14, 2013 - 08:23 PM
And I finally got the tower off of it too.  Just finished that.  The problem was the pin holding the drive engaging lever to the shaft.  It was frozen in place.  I finally had to grind the head off of it and get out the air hammer to drive it out.  and it worked!
[attachment=55697:100_8981.jpg]              [attachment=55698:100_8980.jpg]
[attachment=55699:100_8982.jpg]              [attachment=55700:100_8983.jpg]
[attachment=55701:100_8984.jpg]              [attachment=55702:100_8985.jpg]
#8 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted January 16, 2013 - 08:50 PM
Looks like fun! i need a new project.
#9 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted January 16, 2013 - 09:15 PM
How old are they, really not to bad for being that old, a lot of surface rust-could have been worse. The H1 with the crack in it shouldn't be a problem, get it tig welded and ground down-good as new. The cooling fan in the H3 looks like it hadn't turned in many a years.
A nice project.
Dick
